sidelined again !!!!!!!!
- geerbangr
07 Sep 2006 12:08
1978 KZ 1000
I go by Jason
I go by Jason
- guitargeek
Re: sidelined again !!!!!!!!
07 Sep 2006 12:54
I'd start by checking the gear oil in the rear end for proper level, then drain it and see if there are any metal bits in there. If that looks okay, I'd pull the rear wheel and inspect the ring gear. If that's okay I'd pull the drive shaft and check the U-joint(s). If that looks okay I'd pull the swingarm and inspect the bevel gear.
If I had to pick just one, I'd say it was a bad U-joint...
1987 KZ1000-P6 "Ponch"
1979 GS1000 "Dadzuki"
- guitargeek
22 Sep 2006 02:49
So what'd you figure out?
- geerbangr
23 Sep 2006 07:28
The front bevel gear bearings took a shit!!!
1978 KZ 1000
I go by Jason
I go by Jason
- wireman
- geerbangr
23 Sep 2006 23:46
Not a real bad job wire,pull the front gearcase off,pull the rear of the case out that the shaft connects to,pull the dust cover off the outside,back the nut off the shaft,push the main shaft out,the outside bearing race can be knocked out with a drift,the inner bearing race,hahahaha ,had to pull an old mechanics trick to get that dude out,there is noway to push,drive,knock,coax,or swear that race out,fire up the mig and run 2 1" beads opposite of one and other then pull the race out with a pick:woohoo: just got all the parts to put it back together,the only critical part is bearing preload,check backlash once all together wash her up and go run the monkey nuts off of her until i break something else!!!:woohoo: :woohoo: :woohoo: :woohoo: :woohoo: :woohoo: :woohoo:
1978 KZ 1000
I go by Jason
I go by Jason
