Now what ????
- geerbangr
Now what ????
06 Sep 2006 18:49
1978 KZ 1000
I go by Jason
I go by Jason
- neilage66
Re: Now what ????
06 Sep 2006 18:56
Might I recommend some JB Weld.
jbweld.net/index.php
Post edited by: neilage66, at: 2006/09/06 21:57
- pstrbrc
- '81 GPz 1100 project
Re: Now what ????
07 Sep 2006 08:22Try acetone. A garage without acetone is like a home without a woman. You know, for cleaning up after you.how the hell do you get the old glue off the cover
superglue. Yeah, really. Betcha that's what they used originally. Just make sure you clean both surfaces well with rubbing alcohol.what kinda glue will keep this new emblem stuck on there for years to come ?????
\'81 GPz 1100 project
Elkhart, Kansas USA
\"Man does not control his own fate. The women in his life do that for him.\" Groucho Marx
Elkhart, Kansas USA
- duncan
Re: Now what ????
07 Sep 2006 15:20
pstrbrc wrote:
acetone will dissolve the old glue on the sidecover, but will also dissolve the paint.
after i cleaned the rust inside my gas tank, i rinsed the inside with acetone to stop the flash rusting (acetone absorbs water), but the acetone spilled on the outside of the tank and smeared the paint.
- Rickman
Re: Now what ????
08 Sep 2006 07:28
3M Trim Adhesive. or 3M Super Trim Adhesive.
1983 KZ1100-L1 "LTD Shaft"
Wiseco 10.5:1 1171 piston kit, bored by APE
Dyna 2000, Dyna S, Dyna grey coils, WG coil power mod, CB900 starter
