1 simple clutch question???
  • steveo_4192003
  • steveo_4192003's Avatar Topic Author
  • 77kz650b-1
06 Sep 2006 10:48
#74860
sorry for dumb question like this!
my clutch is slipping at higher speeds (5000 rpm and above)i think it need friction plates or!!!
do i need to drain oil before i take clutch cover off to check checking the mechanical release and other componets?
this is my first time and dont want to have oil all over me and ground?
what should i check for???
1977 kz650b-1, 4-2exhaust systetm, pod filters ,jetted 112 main, 17.5 pilot
  • Spock
  • Spock's Avatar
Re: 1 simple clutch question???
06 Sep 2006 12:24
#74880
I have the same problem on my 82 KZ-1000.
I have conclluded that I need to replace the friction disks because the clutch lever freeplay is adjusted properly (about 1/4 inch of freeplay) so, I know that it is not partly disengaged.
I have found that it slips if I hold it wide open but, if I back off, it grabs.
I suspect that the oil is contaminated by clutch friction disk material and you should change it anyway. If you lean the bike over on the side stand, you could get by with very little oil leaking out of the open clutch housing (if your bike has the clutch cover on the right side of the engine like it is on mine.
Spock
  • RonKZ650
  • RonKZ650's Avatar
06 Sep 2006 13:07
#74891
On a KZ650 if you attempt to remove the clutch cover without draining oil, you'll get about 3 quarts drain as you remove it. You'll need to drain first.
  • mariozappa
  • mariozappa's Avatar
06 Sep 2006 13:11
#74897
FWIW
I had the same problem on my B1 and I thought it was the plates too.
Once I got in there I found that my clutch springs were worn out and much shorter than my new replacement ones.
If your going to replace the plates then replace the springs too.
YMMV
1977 KZ650C1
and the KZ650/KZ750 Conversion ;)
