I think I found a motor, will old pipes work?
- AJCrader
06 Sep 2006 10:41
Exhaust on eBay
I am going to try to get this as I can't seem to get anything else, wanted to know if my exhaust from a 78 650 will work or if i need to find new ones
Post edited by: steell, at: 2006/09/06 18:05
AJ
Drag bike, 1220cc Z1R KZ project
- apeman
Re: I think I found a motor, will old pipes work?
06 Sep 2006 10:49
That engine should drop right into your KZ650. The KZ750 uses electronic ignition, so you will need the Ignitor from a KZ750. Also, the KZ750 has a different alternator setup. so use the regulator/rectifier from the KZ750 as well. Lastly, the KZ750 uses 630 gauge drive chain. You can use the sprockets and chain from your KZ650, and it will work just fine.
Good luck!
Good luck!
Petaluma and Truckee, CA -- member since Jan. 23, 2003;
PREVIOUS KZs: 1980 KZ750H with 108,000 miles; 1980 KZ750E with 28,000 miles; and KZ750H street/cafe project, all sold a few years back.
This is what I do for fun, not for work. It is art, with a little engineering thrown in.
- Mcdroid
- Gone Kwackers
06 Sep 2006 10:52
AJ:
Just as an aside, the seller is listing that 750/4 model as being a 1978 year model. The 750/4 wasn't available until 1980 in North America...so just to avoid problems in the future, make sure you know what it is he's selling.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- JMKZHI
Last edit: 03 Dec 2008 17:19 by JMKZHI.
- AJCrader
06 Sep 2006 11:28
I appreciate the quick response! I just can't find anything local that is in good condition
AJ
