- Thank you received: 7
Another Cam Question / Another Choice Added
- austin3119
Thanks
Grind Lift: Duration: Timing: TDC: CL: Angle: Lash:
3x In .418 282 deg 37/65 .173 106 .004
Ex .418 282 65/37 .173 106 .004
Post edited by: austin3119, at: 2006/09/06 12:03
- APE Jay
- Visitor
Jay
- craigpuckett
Jay, on another note have you ever thought of grinding the old andrews 6x-4x combo? that was a killer set back in the day for 1170-1260 motors. just a thought
- austin3119
How does this one look?
420 Lift / 269 Duration at .040 / 262 duration at .050 / lobe center 110' / Event In 25/64 Exh 65/24 / base circle 1.110
Thanks
- APE Jay
- Visitor
IMHO APE's 410 grind would be a better streetable choice,I think I read somewhere that they are the old andrews 8x grind.(short duration,high lift=loads of torque)
No. When Andrews quit the import cam business, we bought the masters for the 8X and 5X. They were the most popular. They became our K410 (the biggest you can run with the shims on top), and our K435.
Jay
Post edited by: APE Jay, at: 2006/09/06 22:17
- Jeff.Saunders
The matched set of components is the key. 10.5:1 pistons with 410 lift cams will not be that good if you still run 26mm carbs. Getting the ports cleaned up - possibly going to 37.5mm intake valves will help the motor breath.
www.z1enterprises.com
Z1 Ent on Facebook,
- mark1122
- Keep twisting it
- Thank you received: 109
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Jeff.Saunders
The higher lift cams make more power at higher RPM - and usually lack performance under 4,000 rpm. This makes it tougher to ride around town
Once you go over 410 lift, you have to do much more work to the head - you must switch to shim under buckets, you also need heavy duty valve springs. You really need to get the head flowed. Potentially larger intake valves. The you dive into the rest of the engine - welded crank, heavy duty cam chain, beefed up clutch.
Z1 Ent on Facebook,
- cary
- Sandy
- Fly High,Tony
- Thank you received: 13
would 410's be a drop-in on a '82 1000, stock with with constant velocity 34's (jetted, of course)?
Pretty sure You'd still have to do some clerance grinding on that head...maybe even the valve cover as well,but I'm not positive.
1977 KZ1000 A-1
- RomSpaceKnight
- Thank you received: 2
- APE Jay
- Visitor
Not a drop in. Must clearance the tappet bore area ( not valve cover ) and use the VS900K valve springs. Also will not clear stock pistons. We never sold a drop in because for the money, we thought the performance increase did not warrent it.
Jay
