unseizing the kz
04 Sep 2006 16:48 #74480 by Fullmetal
unseizing the kz was created by Fullmetal
so today i started to tear down. got the plugs out and got some PB Blaster in there. been letting it sit all day but no luck thus far in getting it to kick through. any advice what to pursue next?
  • RetroRiceRocketRider
  • ...bring in the machine that goes PING!
04 Sep 2006 17:12 #74485 by RetroRiceRocketRider
Replied by RetroRiceRocketRider on topic unseizing the kz
Depending on how badly seized and/or how long has sat that way, it may take a few days or longer for that PB blaster to free it up. :S
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
89 GSX1100F Katana = SLEEPING :-/
  • wireman
  • Visitor
04 Sep 2006 17:17 #74487 by wireman
Replied by wireman on topic unseizing the kz
dump some gas and tranny fluid down cylinders.;)
04 Sep 2006 19:17 #74517 by 440zrider
Replied by 440zrider on topic unseizing the kz
Marvel Mystery oil works ive been told...My dad used it to free up engines...
04 Sep 2006 19:20 #74518 by kawsakiman
Replied by kawsakiman on topic unseizing the kz
if your sure it's in the cylinders, fill them up with brake fluid.wait a couple of days and slowly work it. takes awhile but brake fluid eats everything.
04 Sep 2006 20:37 #74538 by EddieBoy
Replied by EddieBoy on topic unseizing the kz
I agree with this techique..i have used it quite a few times..takes anywhere from a few hours to a couple of days.The longer you can wait the easier it will be to get apart..
i even freed up a 175cc 2 stroke by setting it in a wash tub completely submersed in diesel fuel..that works good if your going to completely disassemble.
04 Sep 2006 21:01 #74542 by kzmarvo
Replied by kzmarvo on topic unseizing the kz
My ol man use to swear by tranny fluid and time.Never saw anything that it never worked on.;)
Watch it folks,i have sticky fingers when it comes to a nice looking set of handle bars:)
05 Sep 2006 06:26 #74596 by craigpuckett
Replied by craigpuckett on topic unseizing the kz
you could also have some stuck valves,if your trying to turn it over assembled.
if you have the head off you can see what the cylinders have in em.
05 Sep 2006 08:10 #74618 by wiredgeorge
Replied by wiredgeorge on topic unseizing the kz
Florida bike? Hmmm... if the carbs were left off the bike or the plugs left out and the bike sat out for a bit, you likely have rusted cylinder walls. You MUST remove the head... don't try and turn the engine over by hand as you will end up snapping off the manual ignition advance locating pin on the end of the crank if the engine is siezed. Remove the head and you will see a cylinder that is rusted. If this is the case, you can try soaking and then prying the cylinder off. Be prepared to pick up a new block with matching pistons as it isn't likely the rust will be honed through. I have seen this on Florida bikes in the past.
05 Sep 2006 17:00 #74715 by arobsum
Replied by arobsum on topic unseizing the kz
works on sticky valves too.
  • Duck
  • e vica na i sau na ga
06 Sep 2006 03:20 #74783 by Duck
Replied by Duck on topic unseizing the kz
Do not use nut on crank to turn. Put in 2nd or 3rd and rock back and forth. Add mmo or atf daily and try rocking. If no go after a few days, pull it apart. I had a 'free' CX500 that was so stuck the back tire would slide on the garage floor. Got lucky after three days and it freed up. Got even luckier and it's got good compression. $100 CB650F freed up this way too but wasn't as bad.
  • pstrbrc
  • '81 GPz 1100 project
06 Sep 2006 13:21 #74900 by pstrbrc
Replied by pstrbrc on topic unseizing the kz
Man, this made me queasy. Brake fluid definitely contains stuff that will eat the aich eeee double toothpick out of anything non-metal in your engine. I'm thinking seals, cam adjusters, you name it. Oh, it might not disitegrate as soon as you start your motor (if you do ever get it started) but brake fluid will start softening up parts you don't want soft. Then, a couple of thousand miles after it starts running, when you're really proud of yourself for ingeniously using brake fluid for something it was not intended for, BLAMMMMMMM!!!!!!!
\'81 GPz 1100 project
Elkhart, Kansas USA
\"Man does not control his own fate. The women in his life do that for him.\" Groucho Marx
