She's alive but going in and out of coma
- steell
Re: She's alive but going in and out of coma
04 Sep 2006 19:36
No problem, we 750 twin owners have to stick together or the four cylinder owners will take over the world :laugh: :laugh: :laugh:
- ronjones
04 Sep 2006 19:55
steell wrote:
Judging from this group...they already have
:lol: :lol:
- bemoore
05 Sep 2006 05:02
On the brakes, I recommend bleeding as follows: Put the bike on the centerstand and turn the handlebars to the left so that the right side (the side with the master cylinder) is pointing up. Remove the caliper. Press the piston back into the caliper. I used a C-clamp. Remove the C-clamp. Work the brake lever to push the piston back out. Be careful not to push it completely out. Repeat about three times.
This was the majic bullet that finally resulted in a firm brake on my 650.
77 KZ650C1 w/Kerker 4-1
- ronjones
05 Sep 2006 07:24
bemoore wrote:
Thanks for the reply and method, bemoore. The CSR does not have a centerstand. I've been using 2 pieces of 2x4 under the side stand just to get it to stand up straight so the master cylinder is horizontal. Are you just saying to push the caliper in then pump it out...w/o bleeding the caliper or putting fluid into the master cylinder? I think I see how this might work, by pushing air bubbles up the break line but just want to be sure.
Thanks
Ron
Thanks
Ron
- ronjones
27 Sep 2006 17:53
UPDATE:)
Hey guys, I wanted to let you know about my progress.
The best news is SHE'S ALIVE
. I had her out around the neighborhood today. She's running fine right now, except there is an occasional stumble right as I crack the throttle to take off, I'm hoping the sea foam will work through that. I've got her idling around 950 w/the choke closed and starts cold w/several kicks, on full choke. When warm she starts w/1 kick and no choke:) I did several things so I really don't know what fixed her. I put on the Wired George coil mod. I went up to a #50 pilot jet and also found that one of my carb journels was clogged. I think the "Sea Foam" is helping to clean the system and now will get better the more I ride. I still need to balance the carbs and when I get a chance I'll check/adjust the valves. I'm also still getting some cam chain noise, evethough I adjusted the tensioner.
I still have the starter problem. When the bikes cold, something is still slipping and the starter won't crank the engine and I get a chain running on teeth sound. Once she's warmed up the starter kicks her right over. I've got to replace the stator, getting no juice whatsoever, so while I have that cover off I'll see if I can't do something about tightening the chain. It's not that big of a deal as I can always kickstart.
Although I've got the brakes working, they still feel mushy, but driveable. Much better than they had been. I'm going to replace the brakeline w/a braided line. I think I can feel the brakeline "pulsing" when I pump the brake.
Anyway I wanted to thank everyone for all their suggestions and help.
She's a runnin'...ye ha!!!
Ron
Ron
- Shoe48
- Live each day as it is your last
27 Sep 2006 18:12
Any chance of getting a pic of your bike ,, As you can see I own the same bike , I dont have a better pic right now , I used one of those vacumn pumps to bleed the brakes , I would never have got it with out , I changed the Handlebars over so the stock master mouting was at an angle , I had one off a Honda I used on it , It really looks better and works , Much better than non working ,, Yea the twin guys better stick togther m Hey Steell you going to start an advise column ?
i48.photobucket.com/albums/f245/shoe48/100_0924-2.jpg
Post edited by: Shoe48, at: 2006/09/27 21:22
- ronjones
27 Sep 2006 18:18
I haven't taken another pic of it since I took my avatar pic, but here's the same pic but a little bigger.
- Shoe48
27 Sep 2006 18:27
Thought about pods but went with the stock box instead ,, Those carbs are goofy for sure, I raised the needles by about .005 for the after market mufflers , I do like your bike , I have a painter lined up this winter and also will go with blue . I posted a short time ago about mufflers at that time Steel showed me a post about installing Dunstall mufflers , I do have them on now and such a sweet sound ,, More like a BMW .. I will try to get a pic posted soon ..
- Biquetoast
- King Jeremy The Wicked
27 Sep 2006 19:12
ronjones wrote:
YAY!....SHE'S ALIVE....
Sounds like the carbs are out of balance, or the pilot still needs adjustment, or the floats are wrong.there is an occasional stumble right as I crack the throttle to take off....
Hmm. Depending on the sound, might it actually be vavle noise? That would be potentially good, though, since noisy valves are happy valves... to an extent.I'm also still getting some cam chain noise, evethough I adjusted the tensioner.
I don't know. It just sounds like the famous starter clutch failure like all of our twins have.I still have the starter problem....
Ok that's not good. Not likely the line, more likely a off-balance wheel/tire, warped disk, or something like that.I think I can feel the brakeline "pulsing" when I pump the brake. ...
(1.) '75/'76 KZ400D - Sold
(4.) '75 KZ400D - Sold
kz750twins.com
kz750twins.com
- ronjones
27 Sep 2006 19:15
Thanks for the compliments, Shoe
The paint is rattlecan, it didn't turn out too bad but I'm thinking of tearing it down again this winter and doing a better job. I put the pods on because I was sick and tired of trying to work around that dam& airbox, pulling the carbs in and out is a real pain. Since I had everything apart and needed new jets anyway, I decided on doing the pods. I'm thinking of making some half covers for them to protect them from the rain and cross winds.
Git a pic of that bike of yours, I'd like to see it. I'll probably be posting some new pics under another thread when I get her all spiffy
Post edited by: ronjones, at: 2006/09/27 22:16
- ronjones
27 Sep 2006 19:29
Biquetoast wrote:
Thanks
I'm just happy she's running
ronjones wrote:YAY!....SHE'S ALIVE....
I'm pretty sure the floats are good, pilot adjustment and balance are probably the culprets
Could be...I'm going to have someone, who knows more than me, give it a once over when I can get it over to him
Unfortunately I'm sure the chain is comming off the lower sprocket, because I've seen it when I've had the cover off. And I've had the starter rebuilt.
Sorry, a miscommunication. I ment that I've put my hand around the line and I've felt it pulsing when I pump the handle. Not while I'm riding
Thanks
- Shoe48
28 Sep 2006 09:26
Pic of my bike with new Mufflers
i48.photobucket.com/albums/f245/shoe48/100_0992.jpg
I just got these on and some of the headlight parts have comes now ,, so this is it till cold weather come and I do a Paint /Clean up to it , It runs real good now maybe a little rich at idle . those are goofy carbs for sure .. anyway a Thanks to the KZR members that gave advise on my bike
Post edited by: Shoe48, at: 2006/09/28 12:27
