Will not go into 6 gear
- villy
03 Sep 2006 13:21 #74269
by villy
Will not go into 6 gear was created by villy
I have a kz 400 with a engine from 1978. It runs very good. But it wont go into 6 gear. what can be the problem?
- steell
03 Sep 2006 13:48 #74273
by steell
Replied by steell on topic Will not go into 6 gear
I just looked at the parts diagram for a 78 KZ400B at buykawasaki.com, and I only see five gears, so are you sure it's a six speed transmission?
- villy
03 Sep 2006 14:01 #74276
by villy
Replied by villy on topic Will not go into 6 gear
A kz 400-B1 from 1978 has 6 gears.
- steell
03 Sep 2006 14:16 #74278
by steell
I just check the bible (AKA
www.kz400.com/
), and you are indeed correct, the 78 was the first year for the six speed trans.
About all I can suggest is to check out www.kz400.com/ and see if that problem has been covered, at least unless the expert (Ibsen2200) stops by.
- loudhvx
- Thank you received: 1616
04 Sep 2006 00:32 #74368
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic Will not go into 6 gear
Yeah, it seems like the 78 400 B had a lot of new stuff.
1981 KZ550 D1 gpz.
Other links.
