- Thank you received: 1
Help me remove emissions gear!
- Grebnaws Inc.
Someone suggested after hearing my bike that maybe "that's just the way kawasakis sound", referring to the same type of low grumpy idle that many Harleys make. To me it sounds like a poor running bike, not a character trait. My bike experience is limited but my friends Yamaha Virago 650 doesn't run anything like mine. It is silky smooth and revs effortlessly. Mine is rough and the throttle is hard, and far slower (even weighing 75 pounds less and riding a smaller bike)
My bike is a 1983 Kawasaki KZ550 LTD. Carbs were rebuilt by the previous owner (this is verified) and everything looks real clean, but the symptoms remind me of a poorly functioning emissions system. I purchased 4 sets of carb rebuild kits before realizing they'd already been rebuilt, so I'm looking to resell them if anyone would like them.
I have a bike manual although I haven't had time to casually read through everything, so I might be requesting something kinda obvious. If you guys could show me what needs to be done to remove or bypass the emissions on the engine it would be greatly appreciated. Are there block off plates to buy or any extra supplies needed to continue?
- rotinaj13
- JjSwee
Found it: "The other two ports have hoses that connect in a tee fitting. The other end of this fitting connects to a emissions device that is vacuum actuated. If the emissions device which looks like a brass colored cylinder about 4 inches long on most bikes, is gone, the hoses should be removed and vacuum caps placed over the vacuum ports on those carburetors. Any vacuum ports left uncapped create a major air leak that can hole a piston. I also suggest you look at the top of your valve cover if the emissions cannister is gone. there are two hoses up there that will not be connected to anything. These lead to ports in the cylinder head that are now not connected to anything. I would take the hoses off your valve cover and plug the holes in the valve cover with Permatex (black) so that air isn't sucked down into the combustion chamber through your reed valves which may or may not be in place inside the valve cover under the two covers on top the valve cover."
kzrider.com/component/option,com_joomlab...id,3/id,31398/#31398
Here is another link:
kzrider.com/component/option,com_joomlab...id,2/id,27551/#27551
Oh and Post three on this one really describes it pretty good:
kzrider.com/component/option,com_joomlab...id,2/id,55677/#55677
Post edited by: JjSwee, at: 2006/09/03 02:22
- ran429
- Master of FREE rides!
- steell
It will get confused and have identity issues and may require long term group therapySo what will happen to the motor if the reeds arent plugged (removed) and I have a hose looping from one side (right) to the other (left) ?:whistle:
In other words, nothing that I know of, it ought to work fine.
- kawtoy
- Thank you received: 6
Harley Davidson- Turning gas into noise without the harmful affects of horsepower for over 100 years.
- steell
You CAN NOT assume that anything is right without checking it.
That's the critical part right there, and the thing that trips up most people.
Rule #1: Never assume anything!!!!!
Rule #2: Leave the $&^%* carbs alone until you have eliminated every other possible cause of the problem!!:pinch:
- wiredgeorge
- 440zrider
- Thank you received: 2
- JMKZHI
- Thank you received: 48
- Rickman
under the reed valves, there is a straight passageway connected to your combustion chamber.
pretty sure the port goes to the exhaust port on the other side of the valve from the combustion chamber, at least on my 1100 head.
1983 KZ1100-L1 "LTD Shaft"
Wiseco 10.5:1 1171 piston kit, bored by APE
Dyna 2000, Dyna S, Dyna grey coils, WG coil power mod, CB900 starter
- vegasjetskier
