cyllinder install
16 Sep 2006 13:28 #77226 by EscondidoKZ
Replied by EscondidoKZ on topic cyllinder install
Let's try this one
  • APE Jay
  • Visitor
17 Sep 2006 13:21 #77446 by APE Jay
Replied by APE Jay on topic cyllinder install
The photo appears to be a KZ block, and the pistons are J model.
Spacer here;
kzzone.com/blocks.html
Jay
Post edited by: APE Jay, at: 2006/09/17 16:24
  • wireman
  • Visitor
17 Sep 2006 13:26 #77449 by wireman
Replied by wireman on topic cyllinder install
thats why they pay him the big money!;)
18 Sep 2006 07:56 #77633 by EscondidoKZ
APE Jay wrote:
If the pistons are for a J head, they would be part# K1106. The J motor has shorter rods, so the J pistons have the pin holes lower than regular KZs. If you put them in a motor with a KZ long rod crank, the pistons will hit the head.
You need a spacer plate under the block. .040" will work if you are using a base gasket on both sides. You can use .063" with no base gaskets.
Has the head been modified to use on the KZ style engine?
More info here;
www.aperaceparts.com/tech/techkz1000.html
Jay
Jay
Will the 0.040 spacer on the KZ head and cylinder lower the compression with the J model pistons?
  • APE Jay
  • Visitor
18 Sep 2006 16:14 #77713 by APE Jay
You are really confusing me. Which head do you have??? Show us a photo of it too.
Jay
18 Sep 2006 18:53 #77729 by EscondidoKZ
It's the stock head off a 76 KZ900 also the Pistons have 4549ps on them if that helps. Sorry for the confusion.
