GPZ cam specs?
- Exitpupil
GPZ cam specs?
02 Sep 2006 17:54
Just curious what the lft/duration specs for a GPZ1100 cams are so I can compare to aftermarket?
79 KZ1000 LTD B3, 1075 kit, BS34 carbs, high velocity ported heads, K410 cams, V&H pipe w/custom baffle
- larrycavan
Re: GPZ cam specs?
03 Sep 2006 15:14
The only GP11 cams worth putting in a KZ or J would be 83 - 85 models.
If adapting to a KZ, you can do it using Allen bolts and redrilling the stock KZ sprockets.
Lift is roughly .390". Duration specs from Kaw will be significantly longer than aftermarket cams due to Kaw's OEM low lift checking point. Seems to me like it's .3 or .4mm where they spec duration.
Yes it's a pretty good cam for a stock or low mod motor. Make certain you check your tappet bore clearances if you try these cams. I have run them in KZ1000 with top bucket shims and not had any problems..
Post edited by: larrycavan, at: 2006/09/03 18:15
- Exitpupil
Re: GPZ cam specs?
04 Sep 2006 15:11
Thanks Larry. I am perking up my KZ 1000 in hopes of getting it to perform like the 83 GPZ I stupidly let go once upon a time. Sounds like my aftermarket cams will be close to the GPZ.
