Oil Pressure Switch - Leaking?
31 Aug 2006 15:24 #73717 by Mandrake
Oil Pressure Switch - Leaking? was created by Mandrake
I've noticed a little puddling of oil around the base of the oil pressure switch/sensor and on the unit itself recently (KZ1000J). I cleaned up the unit and ran it for a while and couldn't detect an obvious source, so I was wondering if it is common to get seepage around the bolts or the base of the unit. I've had the bike now for a few hundred miles and just recently changed the oil.
Any experience??
31 Aug 2006 15:41 #73718 by fixer5000
Replied by fixer5000 on topic Oil Pressure Switch - Leaking?
take it out and put a little removeable ( blue ) loctite on it and put it back...steve
1978 kz650b pretty much stock
massachusetts
