  • JMKZHI
  • Topic Author
30 Aug 2006 07:51 - 22 Feb 2013 11:19 #73393 by JMKZHI
. was created by JMKZHI
Last edit: 22 Feb 2013 11:19 by JMKZHI.
30 Aug 2006 08:42 #73408 by weirdooh
Replied by weirdooh on topic Feeler gauge for Valves
last time I did this I used a straight set. Are the angled feelers long enough?
  • Duck
  • e vica na i sau na ga
30 Aug 2006 12:26 #73443 by Duck
Replied by Duck on topic Feeler gauge for Valves
I bought some guage stock from MSC. Only need a couple of sizes and it's cheap. IMO it's easier to 'feel' than with the multi-guage tools. Bend one end and you can have it both ways ;-)
  • JMKZHI
  • Topic Author
30 Aug 2006 13:20 - 22 Feb 2013 11:19 #73452 by JMKZHI
Replied by JMKZHI on topic .
  • Duck
30 Aug 2006 15:47 #73487 by Duck
mscdirect.com
overnight delivery of all that stuff you want overnight.
stuff like
tap extractors for removing broken taps
reams, left hand drills, monkey skull crackers, helicoils and timeserts, and all sorts of cool tools, hardware, and materials.
30 Aug 2006 16:17 #73501 by kawtoy
Replied by kawtoy on topic Feeler gauge for Valves
The angle ones work better I think. The straight ones seems to hit the hard when trying to get under the cam lobe. Just make sure you get one that has the real small sizes with it.
Harley Davidson- Turning gas into noise without the harmful affects of horsepower for over 100 years.
30 Aug 2006 20:21 #73563 by N0NB
Replied by N0NB on topic Feeler gauge for Valves
I bought a set at the local NAPA store and while it's primarily guaged in thousandths of an inch it does show the metric size as well. The set I bought had the smallest leaf at .002" which is also .051mm then it went up to .003, .004, etc.
I just did my valves on the 650B and it worked well. My compression discrepancy has largely disappeared as one valve was tight before.
- Nate >>
Nate
1979 KZ650 (Complete!)
1979 KZ650 SR (Sold!)
1979 KL250 (For sale)
1994 Bayou 400 (four wheel peel :D )
  • JMKZHI
  • Topic Author
30 Aug 2006 20:32 - 22 Feb 2013 11:19 #73566 by JMKZHI
  • Duck
31 Aug 2006 03:03 #73604 by Duck
see starrett metric stock, lower right Four strips, 0.03, 0.05, 0.10, and 0.15mm will do the trick
  • JMKZHI
  • Topic Author
31 Aug 2006 07:41 - 22 Feb 2013 11:19 #73625 by JMKZHI
