shifter leak
- p_apac
29 Aug 2006 10:16 #73202
by p_apac
shifter leak was created by p_apac
i have a 83 kz750 spectre and when i got the bike i had no leaks. but since a few oil changes and about 3000 miles this summer its now leaking from where the foot lever gooes into the shifter. i have taken off the cover and cleaned it all up and made sure were the leak was coming from. i was wondering if this is a job for someone to do at home or should i take it to a shop?
- 750LTDRider
29 Aug 2006 10:28 #73207
by 750LTDRider
Replied by 750LTDRider on topic shifter leak
Just changed this seal on mine. You can actually do it without removing the cover. I just used a screwdriver to pull the old one out, screwed it up good but it was bad anyhow. You can then tap the new one into place and say goodbuy to the leak.
- mark1122
- Keep twisting it
- Thank you received: 109
29 Aug 2006 11:07 #73213
by mark1122
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Replied by mark1122 on topic shifter leak
Dont forget to put some oil on the inner ruber seal part so you dont damage it while installing it.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
