Engine Cleaner or Polish
- Frazzles
28 Aug 2006 22:15 #73122
by Frazzles
Engine Cleaner or Polish was created by Frazzles
What is a good Engine Cleaner or Polish to get the engine looking clean. Also what is a good degreaser to get a lot of the dirt off.
Thanks,
Newb, i mean Eddie
Thanks,
Newb, i mean Eddie
- Stvsnclr
28 Aug 2006 23:54 #73129
by Stvsnclr
Replied by Stvsnclr on topic Engine Cleaner or Polish
I just used Simple Green to de-gunk my swing arm, and it worked very well. I like it because it cuts through the grease and grime but isn't as harsh as the spray-on solvents. Use Mothers aluminum polish to shine up you cases. You can spray WD-40 on you cylinders (after they're clean) to get them nice and shiny.
- wireman
- Visitor
29 Aug 2006 02:14 #73140
by wireman
Replied by wireman on topic Engine Cleaner or Polish
aluminum wheel cleaner works good for cleaning engines spray it on rinse it off,then polish with mothers aluminum polish.
