Engine Forum
Engine forum is a tech forum for "Engine" topics.
How much oil will drool out?
  • farmer fred
  • farmer fred's Avatar Topic Author
24 Aug 2006 07:34
#72100
I want to replace the clutch cover and inner points housing (PO had them chromed, and I have non-plated versions I will polish up and use) and need to know if I should drain the oil. This is a 78 LTD 1000 with a very short sidestand so it leans over pretty far to the left.
TIA
  • Sandy
  • Sandy's Avatar
  • Fly High,Tony
Re: How much oil will drool out?
24 Aug 2006 08:38
#72112
You're going to get a couple liters at least,I would think.I've never pulled those covers without draining the oil first,so I can't say for sure.
I would drain the oil though...less mess.
Do You have a new seal to put in the cover behind the ignition?...You should get one to put in while You have it apart now,instead of having to do it later on...much easier now.B)
1977 KZ1000 A-1
  • btchalice
  • btchalice's Avatar
24 Aug 2006 11:30
#72181
if you lean it far enough not much but if your going that far why not do an oil and filter change while your down there
Post edited by: btchalice, at: 2006/08/24 14:31
Terry Meyer / Wichita KS
76 kz900 w/1000 motor TWZTD
