KZ 900 Compression Ratio
  • mudman257
  • mudman257's Avatar Topic Author
08 Nov 2005 11:34
#7184
Hey I have a '76 Kz 900 and i didn't know what the compression ratio is on it.
  • wiredgeorge
  • wiredgeorge's Avatar
Re: KZ 900 Compression Ratio
08 Nov 2005 11:40
#7185
8.7:1 - Use regular gas.
  • wireguy
  • wireguy's Avatar
17 Nov 2005 22:21
#8766
depending on if its stock or not 8.7:1 if the motor is tired it could be lower,pull the plugs and run a compression test(psi)and see what you get they should all be fairly close
