Consequences of Overfilling Oil?
- Maverick
22 Aug 2006 19:26
Hi everybody,
I have the opportunity to buy a 79 KZ650 for relatively cheap. The previous owner filled the oil to the bottom of the filler cap instead of to the top of the window and tried to run it like that. The damage that is evident is blown seals. Any other potential damage that could be the result of overfilling the oil? Just trying to see if it will be a cost effective project for the asking price.
Cheers!
Mav
Cheers!
Mav
1981 KZ1000M1
- Papa Uff Da
Re: Consequences of Overfilling Oil?
22 Aug 2006 19:58
Well in my most un mechanical observation...An inexspensive bike ;-)Other than that I have no idea.
- reborn650
22 Aug 2006 21:32
Hey Maverick. Pull the plugs and try to take a look down into the top of the piston. There is a slight (I said slight) chance that the oil needed a place to escape to and filled the cylinders.
If this is the case you will likely need to pull the motor apart to replace the seals and also for a thorough cleaning.
-1998 Jeep TJ Wrangler 4.0...
- steell
23 Aug 2006 04:03
I have seen holed pistons result from over filling the oil also.
- Duck
- e vica na i sau na ga
23 Aug 2006 04:32
Exceptionally nice bikes are much harder to find than good engines which are much harder to find than good used engine parts.
If it's a beautiful bike and inexpensive, I'd jump on it and worry about the engine later.
-Duck
Post edited by: Duck, at: 2006/08/23 07:33
-Duck
- flht1997
23 Aug 2006 06:03
were they able to start the bike with that much oil in it? the crank had to be submerged! if it was not started just drain it out, pull the plugs out to look in there, the refill and try to start it.
Matt Milwaukee, WI
75' KZ400, (5) 78' KZ400, 76' KZ 750, 78' KZ650
78'CB750F, 78' CB550K
89' BMW R100RT
05' H-D Electra Glide
06' KLR650
Do it right or don't bother doing it at all.
89' BMW R100RT
06' KLR650
- Maverick
23 Aug 2006 08:11
Yes, I guess it would start, but it wouldn't run very good (surprise...), and the result was the blown out seals... Once the oil volume was corrected, it was only run for about 50-100 miles with the leaking seals...
1981 KZ1000M1
- MDawnz1
24 Aug 2006 19:34
Just tell them its junk and they should let you take it off their hands for free, and they should thank you for doing it !!!
People that dumb and Kawasakis dont mix.
1974 Z1a, still 903
