- Thank you received: 7
Compatibility?
- austin3119
20 Aug 2006 10:28 #71095
by austin3119
Compatibility? was created by austin3119
Ok, I've decided to do a 1075 kit on my 76kz900a4 . I found a donor I think for the cylinders ( so I won't have to sleeve mine) from a 80's kz1000 police bike. Will this be compatible?
Thanks,
Austin
Thanks,
Austin
- wireman
- Visitor
20 Aug 2006 12:41 #71114
by wireman
Replied by wireman on topic Compatibility?
after 1980 they went to the j-motor series im pretty sure.you can convert to the newer style head but i think cylinder is differant.
- Duck
- e vica na i sau na ga
20 Aug 2006 17:54 #71175
by Duck
Replied by Duck on topic Compatibility?
J block has slide guides for cam chain. kz has roller. Have
heard that slide is more efficient. How about comparing the
sleeves from the police bike to the 900. 998->1075 should not
be too much of a stretch, Will save having to buy sleeves. What
you really want is the 1015 block from the kz1000. Buy one
with worn sleeves and save some $.
-Duck
-Duck
