valve guide
20 Aug 2006 02:52 #71033 by z1achim
valve guide was created by z1achim
hi kz-rider.
here are pic`s of repair of my cylinderhead with special new valve-guide`s.this is an important problem of all
old z 1 900 head`s.
if ask postet me by questions.
greetings achim
Post edited by: z1achim, at: 2006/08/20 05:55
Post edited by: z1achim, at: 2006/08/20 05:56
20 Aug 2006 05:48 #71049 by steell
Replied by steell on topic valve guide
Click on "Reply" to add more pics, not "New Topic", that keeps everything in one continuous thread, not scattered around.
I deleted the other ones so you can repost them under this one.
Makes things a lot easier to read and understand that way :)
20 Aug 2006 06:47 #71060 by z1achim
Replied by z1achim on topic valve guide
valve guide
20 Aug 2006 06:48 #71061 by z1achim
valve guide
20 Aug 2006 06:49 #71062 by z1achim
valve guid
20 Aug 2006 11:40 #71103 by hwms
Replied by hwms on topic valve guide
Interesting photo;s. However, the last photo brings to mind the old saying "do not use force. Use a bigger hammer"
  • APE Jay
  • Visitor
20 Aug 2006 21:52 #71252 by APE Jay
Replied by APE Jay on topic valve guide
Don't understand if there is a guestion being asked, but I sure hate to see valve guides installed with a hammer.
Jay
21 Aug 2006 00:35 #71269 by nads.com
Replied by nads.com on topic valve guide
I hammed one out backwards with a hammer once, you'd really have hated to see that. Every guide i've installed was with a hammer and lube. Got to admit it beats them up though. I have to pre-ream them or the reamer won't fit once it's insalled. My reamer is a worn valve with the head cut off. Two of them actualy, you know differenty sizes. If your good, you can install both cams and turn one untill it stops (valves hitting) then just clamp the vise-grip tighter and turn harder. Once the vavle is bent u git ta straighten it out with a hammer on the vise. Maybe 100 hits or so and she'll fit in the guide and seal to the seat. Ape is considering my application, NOT.
Post edited by: nads.com, at: 2006/08/21 03:38
21 Aug 2006 07:38 #71306 by OKC_Kent
Replied by OKC_Kent on topic valve guide
Anyone care to share the right way to install a guide?
:unsure:
Oklahoma City, OK
78 KZ650 B2 82,000+ miles
21 Aug 2006 08:25 #71320 by z1achim
hi
the proceeding cannot show complete,but i have to repair
many Z 1 head`s.hate or not hate,my method are practicable and better than work with commpressed air.
the pic with a hammer is only for discribe the method.
there are to many details to show here
examples:
1.valve guide ./. 70° Celsius
2.Head + 120°C
3.Valve Guide, larger outside diameter (special Guide)
is not from KAWASAKI
4.You need many special tools etc.
greetings achim
21 Aug 2006 11:32 #71377 by craigpuckett
Replied by craigpuckett on topic valve guide
Jay;
would it be better if he shimed/wedged the head up to 30.5 degrees on a press and used the press instead of the hammer??
I see he has a bushing in the lifter bore to keep the guide driver strait.
I use the old manley guide puller that locates off of the valve seat.
with manley not selling that tool anymore it makes me wonder if its the right way to go.
21 Aug 2006 14:10 #71404 by z1achim
hi
with special tools i can drive the valve-guide goal-exactly in the direction of the valve seat.afterwards mill the seat (45°=0,09-1,1mm),and than grind the valve on the seat.in the end examine for tightness.that`s my way and my head is running with
1075ccm yoshimura at the year 2000,12000 km(miles ?)one
needs a little strength over force the guide in to the head.the picture is deceptive.with one a heavy hammer can out the wrist work.next i tke a tweezers.i see already which one does not understand me.ok.this was my last contribution in english.
greenings achim
many ways lead to rome
Post edited by: z1achim, at: 2006/08/21 23:16
