- Thank you received: 2
Buying KZ1100 a mistake maybe?
- Mikes82KZ1100
- RomSpaceKnight
- tganek
- Visitor
... I'm wondering if buying the KZ1100 was a mistake. I was hoping to be getting a reliable bike capable of at least close to the 200,000 mile mark...
Not trying to be flip, but you want a Toyota.
- donthekawguy
- Thank you received: 8
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
- RomSpaceKnight
- Fourtoes
- steell
I'm sure there are other people here that remember when cars were worn out at 100k or less.
Every motor lasts a finite number of revolutions, the faster you spin it the faster it wears out.
Post edited by: steell, at: 2006/08/16 07:16
- Duck
- e vica na i sau na ga
old high mileage bikes and cars will both be 'loose'. if you want tight, you rebuild. Otherwise you fix stuff as it wears to the point of not working as it should, which is a relative state
i'm trying to find a used block for my 1100. on the forum with the guys with $ rolling out their pockets the only solution is sending it out for new sleeves. i'm happy with used and 'still in spec' maybe from a 10k or 20k mile bike (no $ falling out of pockets here. have to wait for $3.25 pitcher special before I go drinking with buds).
back to bike. if you want a tight bike, buy a new one, i like the bandit 1200 because it doesn't need water. to make one of these old bike feel like a modern bike will cost a lot of time and $.
Post edited by: Duck, at: 2006/08/16 08:33
- Mikes82KZ1100
- Duck
LIke I said in the previous post, plenty of police KZ1000 with 100k miles and still going strong and it's practically the same engine.
Mine needs jugs at 20k miles because PO effed one up. Otherwise it would have good for another 60K+ easy if the PO hadn't run the snot out of it with too lean a mix.
-Duck
- waterman
I have a 1995 Subaru that I bought 3 years ago with only 65k on it--it will never see 200k, while many other Subarus will. Not a bad car, but most days I only put a mile on a car and it kills them. Bikes are the same.
- tganek
- Visitor
... there is just no sense in having a bike that will only last a year or two. I know of several Voyagers and Goldwings with over 200K and still run great and use no oil.
What's up with the negative waves so early in the morning?
There is nothing on the planet that will not need maintenance to get you through 200,000 miles.
NOTHING.
Not a pair of shoes, a bicycle, or sailboat, or Segway.
If you don't beat on the bike it will be fine! Will it need work? Yes.
oh wait, I forgot about the Perpetual Motion machine I have in the shed. You can have it for an even up trade. PM me.
