- Thank you received: 1
How do you remove old chrome?
- inline4
I tried the piece against a wire wheel on my buffing set-up but was NOT satisfied with the results.
Any suggestions?
- wireman
- Visitor
- steell
Plating Onto Chrome With Gold
Chrome cannot be plated onto. You must strip the existing chrome using an acid solution consisting of 2 parts water to 1 part muriatic or hydrochloric acid. ALWAYS ADD ACID TO WATER. Chrome plate can also be buffed or blasted off.
According to Caswell anyway.
- EddieBoy
- wireman
- Visitor
- wireman
- Visitor
- pumps
- Thank you received: 3
Check out our site. kcvjmc.org
1977 Yamaha XS650
2000 Kaw W650
2 KZ440 LTDs , a 79 KZ400H and an 83 Belt Drive
- wireman
- Visitor
- WTF!
Don't mind fixing but the ol cleaning is a hassle
Cheers
Steve NZ.
- wireman
- Visitor
- OneShoe50
- 10-4? 10-4!
I'm not sure if this would help but I did see the results in this case.
77 KZ1000A1 - Under going a psuedo ELR overhaul
79 KE175 (gone)
81 KZ550A2 (gone)
81 KZ750E (gone)
Sure it looks OK now, but wait until I really make it pretty, with some chrome and paint and some new tires and grips and the wiring. Don't forget the gearing, and the LED's and, and, and....
