just some questions
  • wagonmaster69
  • Topic Author
  • 78 KZ1000A2 / 82 KZ1100 Spectre
13 Aug 2006 16:05 #69163 by wagonmaster69
just some questions was created by wagonmaster69
Hi I finaly getting my 78 KZ1000 tomorrow and need to know what all I sould do to get it running with out hurting it it looks like it has been awhile since it been ran and other that taking the plugs off and squirt some oil in the cylinders what els sould I do?
  • wireman
  • Visitor
13 Aug 2006 18:41 #69193 by wireman
Replied by wireman on topic just some questions
check oil,if it looks too nasty go ahead and change oil.change gas,check plugs.if its been sitting a long time i would pull plug wires and crank motor over a few times to get a little oil to top of motor before you start it.
13 Aug 2006 22:01 #69230 by agawam
Replied by agawam on topic just some questions
If it hasn't run in a while I would pull the plugs and put in some marvell mystery oil and squirt some penetrating oil in the cylinders,then change the oil, pull the air filter and check for critters, get a new battery,plugs, turn it over without the plugs in(after the oil in the cylinders has set a while)and bring up the oil pressure,check carbs to see that they move, lube all the cables(from top to bottom) work them a bit to free up the bind, oil the chain, change the gasoline at the same time check the petcock, gas and vacume lines,put in new plugs and check points(if it has them) now see if it runs
  • wagonmaster69
  • Topic Author
14 Aug 2006 12:56 #69363 by wagonmaster69
Replied by wagonmaster69 on topic just some questions
Thanks for all the advice now I got to get a motorcycle licens but I do know how to ride and it not hitting the road untill I get it .:whistle: :whistle:
14 Aug 2006 17:41 #69443 by vegasjetskier
Replied by vegasjetskier on topic just some questions
I would also check the brake pads and change the brake fluid.
14 Aug 2006 17:42 #69444 by vegasjetskier
Oh, yeah, you also might want to check the valve clearances after you get her running.
  • wireman
  • Visitor
14 Aug 2006 21:11 #69526 by wireman
get it running first before you get carried away with the rest of bike,one fiasco at a time i always say!:P
