Oil filter bolt
- SimonTemplar
12 Aug 2006 16:33 #69001
by SimonTemplar
Oil filter bolt was created by SimonTemplar
I have to replace a bolt from the oil filter/side cover on my '77 KZ750 (B2). The bolt which holds on the side cover over the oil filter, and goes into the oil filter, has a completely stripped head. I was able to get it out but now have to replace it of course. So far I've seen it listed for like $60.
Does anyone know of a cheap(er) alternative??
While only an actual OEM kawi bolt work?
- RetroRiceRocketRider
- Thank you received: 29
12 Aug 2006 16:39 #69003
by RetroRiceRocketRider
Replied by RetroRiceRocketRider on topic Oil filter bolt
Unfortunately the oil filter bolt for your bike (Kawi part# 92003-189) lists as only fitting the '76 ~ 82 KZ750 twins, so finding a non-OEM replacement might prove a task.
Have you checked on eBay or with Jeff Saunders at Z1 Enterprises yet?
- KawasakiBob
- Thank you received: 1
12 Aug 2006 17:13 #69008
by KawasakiBob
Replied by KawasakiBob on topic Oil filter bolt
Hmmmmm.
According to the aftermarkets like Emgo, they're both an 89mm bolt and is supposed to work on both the 16009-002 and 16009-003 oil filters.....
But again, the OEM numbers show they are different...
Yeah hopefully Jeff from Z1 can shed a little light, because if they are able to use the same ones, the EMGO one is only about 10 bucks..
- trippivot
- Thank you received: 3
13 Aug 2006 07:04 #69070
by trippivot
Replied by trippivot on topic Oil filter bolt
the emgo is a good one
the stock ones have two different wrench hex sizes
1 is a 12mm hex
the other is a 14 or 17 the different kawasaki part #
is because of that.
otherwise the same diameter and length
1 is a 12mm hex
is because of that.
- SimonTemplar
14 Aug 2006 09:02 #69314
by SimonTemplar
Replied by SimonTemplar on topic Oil filter bolt
Which EMGO bolt am I supposed to be looking at?
The 17100 seems to go to all the Kawasaki models they list, but they don't list mine so just wanted to make sure.
Post edited by: SimonTemplar, at: 2006/08/14 12:09
- SimonTemplar
20 Sep 2006 18:04 #78333
by SimonTemplar
I haven't been able to confirm which emgo bolt is the one you guys were talking about. Do any of you know the emgo part # for the bolt??
