Tachometer install
11 Aug 2006 10:57 #68764 by squints
Tachometer install was created by squints
I got an 82 kz1000 CSR. to replace this part, i just yank it out and slide a new one like this ( see link ) in instead. Thats it?? It can't be so easy:P
cgi.ebay.com/ebaymotors/KZ550-KZ650-KZ75...mZ180016201880QQrdZ1
traded my classic Kz's for a 2001 Kz1200r
Upstate NY
11 Aug 2006 11:37 #68771 by Spock
Replied by Spock on topic Tachometer install
You have the expensive kit that includes the housing.
Most people get the cheep kit that only includes the seals. You just need to remove the nut that holds the flat (hold down) plate and use a set of plyers to pull out the housing. The Tach Drive Worm Gear and Shaft may come out with it but this is easy to put back in.
I did this on an 82 KZ-1000 CSR with a Vetter faring in place and it was still pretty easy.
Take care you do not screw up the stud for the nut that holds the flat plate.
Spock
11 Aug 2006 11:37 #68772 by Spock
Replied by Spock on topic Tachometer Drive Seal Kit Install
Post edited by: Spock, at: 2006/08/11 14:38
Post edited by: Spock, at: 2006/08/11 14:59
14 Aug 2006 08:04 #69301 by squints
Replied by squints on topic Tachometer Drive Seal Kit Install
With the Fairing..AMAZING. That thing is a b#*ch to get at without a fairing, I can't imagine with.
So, where could I get this kit with only seals. That link above was only for reference.
Thanks, Live long and prosper
Upstate NY
17 Aug 2006 09:00 #70236 by squints
I've been looking - where can i find just the seals? o-ring?
HELP!
Upstate NY
17 Aug 2006 09:10 #70237 by ltdrider
Replied by ltdrider on topic Tachometer Drive Seal Kit Install
Z1 Enterprises probably has the seals for your tach drive.
www.z1enterprises.com
Find your bike model, then check Engine Parts. You may have to look at several pages to find it.
The o-rings should only cost two or three dollars. It will probably cost more in shipping.
'76 KZ900 LTD (Blaze)
'96 Voyager XII (Dark Star)
Greensboro, NC
17 Aug 2006 09:11 #70238 by dutchz
Replied by dutchz on topic Tachometer Drive Seal Kit Install
Try Z1 Enterprises www.z1enterprises.com
1974 Kawasaki Z1
Stock front hub and rear axle.
17 Aug 2006 09:12 #70239 by dutchz
I'm sloooooooooow
1974 Kawasaki Z1
17 Aug 2006 13:04 #70319 by squints
huh, its easy when you know where to look. I should've known to look there first.
IS this what I need. All I need?
www.z1enterprises.com/detail.aspx?ID=1587
Upstate NY
18 Aug 2006 07:08 #70577 by ltdrider
My tach drive has two o-rings, and the oil seal. Don't know if yours is the same, but if it has o-rings on the barrel of the drive unit, then you may need to replace them as well.
Here's what mine lookes like:
Greensboro, NC
20 Aug 2006 07:03 #71063 by koolaid_kid
Replied by koolaid_kid on topic Tachometer Drive Seal Kit Install
I have also seen these kits on Ebay. Be sure and replace all the seals and orings, or you will be doing it again. I think the 2 oring/1 seal configuration is pretty standard for Kaws.
1983 GPz 750
810 Wiseco, Kerker, K&N, DynoJet S3, Accel, Progressive, etc.
25 Aug 2006 05:18 #72352 by squints
Ok, now whats the easiest way to remove that seal. Its in there pretty good. Can I just cut it out since I won't be using it anyway?
I got the o-ring off safely, but that seal won't budge.
A little help.....:huh:
Upstate NY
