Oil filter element fence question
- oldcoldankles
10 Aug 2006 21:06 #68656
by oldcoldankles
Peachland BC
1981 KZ1000 CSR M1
1983 KZ550 LTD M1 (Shaft)
1989 Corvette coupe
Oil filter element fence question was created by oldcoldankles
Can someone explain what the purpose of the oil filter element fence is? Both my KZ's take the same oil filter element,NAPA p/n 4941 (Wix) and the parts, except for the fences, are identical. The fence on my KZ550 sits under the filter element so I've always assumed it was a weir which the oil spilled over. However the fence on my KZ1000 is slightly different and sits on top of the filter element, dispelling my spill over theory
Peachland BC
1981 KZ1000 CSR M1
1989 Corvette coupe
- wiredgeorge
11 Aug 2006 06:29 #68700
by wiredgeorge
Replied by wiredgeorge on topic Oil filter element fence question
Not sure what part you are referring to when you mention a fence. Oil filter, o ring, washer, spring and the bolt are all I can think of with respect to the oil filter stuff...
- oldcoldankles
11 Aug 2006 06:46 #68707
by oldcoldankles
Peachland BC
1981 KZ1000 CSR M1
1989 Corvette coupe
Replied by oldcoldankles on topic Oil filter element fence question
It is the dish shaped metal plate which covers one end of the filter element. Referred to as fence in the manuals but called plate in the Kawasaki parts diagrams.
Peachland BC
1981 KZ1000 CSR M1
1989 Corvette coupe
- wiredgeorge
11 Aug 2006 11:36 #68769
by wiredgeorge
I know what you mean now... can't recall seeing one on my 900s or 1000s...
- JMKZHI
- Thank you received: 48
11 Aug 2006 12:51 - 03 Dec 2008 18:43 #68787
by JMKZHI
Replied by JMKZHI on topic .
del
Last edit: 03 Dec 2008 18:43 by JMKZHI.
