tiny o ring/ oil-filter change, seepage
- jeffZL1000
09 Aug 2006 18:34 #68384
by jeffZL1000
tiny o ring/ oil-filter change, seepage was created by jeffZL1000
the small o ring that purportedly belongs b/t the outer shell and the long bolt that the element assembly spins and mounts with, once i finally figured out where it belongs, always tends to tear and cause oil seepage.
do u guys use these rings with success?
for years i never knew where it belonged and screwed the housing down without it.
no, i am not the smartest guy wandering the aisles.
so what's the trick ? just a wee bit of torque like the book says?
- 77KZ650
- Thank you received: 7
09 Aug 2006 19:01 #68387
by 77KZ650
07 MDP Rookie of the Year
Replied by 77KZ650 on topic tiny o ring/ oil-filter change, seepage
are you putting the o ring on dry or lubed with motor oil?
- jeffZL1000
09 Aug 2006 19:23 #68399
by jeffZL1000
Replied by jeffZL1000 on topic tiny o ring/ oil-filter change, seepage
well not reeeeeeeal dry, but perhaps not wet enough?
- 77KZ650
09 Aug 2006 19:37 #68407
by 77KZ650
dont be afraid to get a good coating on it, you can wipe up drips after.
