clutch will not engagae HELP!!
09 Aug 2006 16:35 #68357 by odl666
clutch will not engagae HELP!! was created by odl666
I have been working on a 1978 kz650b, when i removed the sprocket cover to take off the chain and oil it down. The clutched worked great before this but when i put on the clutch/sprocket cover i cannot get it to grabb. The lever has good teension and snaps back fine but it just does not grab. Whats up? i also have taken out the rod that goes through the casings and hooks up to the cover could i have put it in wrong or is there some kind of thing its supposed to hook too? thanks :(
1978 kz 650b with gpz faq mods cams carbs polished and ported
1979 gs750e
1972 bsa lightning under construction
09 Aug 2006 17:45 #68372 by RomSpaceKnight
Replied by RomSpaceKnight on topic clutch will not engagae HELP!!
Did you lose the ball bearing that resides at the other end of the clutch pushrod?
10 Aug 2006 05:05 #68458 by trippivot
Replied by trippivot on topic clutch will not engagae HELP!!
the lever feels right but no power at the wheel?
is the sprocket and chain secured to the countershaft completley?
10 Aug 2006 10:10 #68507 by odl666
Replied by odl666 on topic clutch will not engagae HELP!!
Well i put the bike in gear and pull the clutch in and it never engages. So i canot take off or anything, also i have no idea about the bearing thing were is it located, is it on the side were the cable goes into? Thanks
1979 gs750e
10 Aug 2006 12:37 #68539 by vegasjetskier
Replied by vegasjetskier on topic clutch will not engagae HELP!!
Sounds like something is binding causing the clutch to remain disengaged. I'd take it apart again and make sure that everyting is in there straight and free.
10 Aug 2006 14:09 #68558 by ltdrider
Replied by ltdrider on topic clutch will not engagae HELP!!
This happend to me.
Turns out the clutch cable was not seated correctly in it's little hole in the sprocket cover. The edge of the cable was stuck on the lip of the hole, so it was stretching the cable like the clutch lever was pulled. But I couldn't tell from the feel of the clutch lever; it felt normal.
'76 KZ900 LTD (Blaze)
'96 Voyager XII (Dark Star)
Greensboro, NC
11 Aug 2006 12:09 #68783 by odl666
still cant seem to get it, i will take some pics this weekend to see if anyone can see whats wrong. thanks
1979 gs750e
14 Aug 2006 17:57 #69447 by vegasjetskier
Did you get it fixed? Where's the pics?
15 Aug 2006 07:11 #69581 by Mandrake
Replied by Mandrake on topic clutch will not engagae HELP!!
I've had some recent adjusting issues with my clutch following changing the sprokets and chain. It took a few tries but I found that I had over adjusted the presuure on the pushrod so the clutch was disengaged continualy. I could actually turn the rear tire with the bike off and in first gear with minimal effort. I am not familiar with your configuation (I have a KZ1000 Police) but I did find a file on the Yahoo KZ1000 Police group under "clutches" to be helpful.
