Z1 crank
  • knackerman
  • knackerman's Avatar Topic Author
Z1 crank
08 Aug 2006 16:11
#68106
I am about to s**tcan the cases on my 78 KZ1000 and replace 'em with a set from a '79. My question is, since I also have a blown Z1 engine sitting in the shed, can I put the Z1 crank into the KZ1000? I've heard that the 900cc Z1 crank will accelerate faster but I really don't want to screw around with this thing forever to make it work.
  • RomSpaceKnight
  • RomSpaceKnight's Avatar
Re: Z1 crank
08 Aug 2006 17:40
#68117
It will drop right in. I believe some if not all the 900 have smaller and lighter pork chops making crank lighter and therefore more willing to accelerate. The only issue is the number of teeth on the cam chain drive. You may need to replace cam chain. I believe there are either 15 or 16 teeth on KZ cranks that determine cam chain length.
  • wireman
  • wireman's Avatar
Re: Z1 crank
08 Aug 2006 19:15
#68140
crank is a drop in through atleast 78 possibly 79 ltd,big pin mkII crank has more teeth than earlier cranks.whats wrong with your 78 cases?
  • loudhvx
  • loudhvx's Avatar
Re: Z1 crank
08 Aug 2006 22:57
#68188
If you change the number of teeth on the crank (by swapping cranks) then you need to change the number of teeth on the camshafts too.
  • RomSpaceKnight
Re: Z1 crank
09 Aug 2006 16:37
#68358
Loud, you positive about that? If you don't do you get a mismatch in crank and cam timing or something?
  • 77KZ650
  • 77KZ650's Avatar
Re: Z1 crank
09 Aug 2006 17:35
#68370
yes, lou is right, think of it like a bicycle, your feet powering the "crank" and the rear wheel being the "cams" if you change gears (number of teeth), the "cams" will be spinning either faster or slower than the "crank", and timing will be off after 1 revolution......there, confusing enough?:silly:
07 MDP Rookie of the Year
  • RomSpaceKnight
Re: Z1 crank
09 Aug 2006 17:43
#68371
:angry: :( :unsure: Hummm, better look at my cam gears. Am in process of putting head on as we speak. Need to come up with correct set of idler gears and wheels. Thanks for heads up.
  • loudhvx
  • loudhvx's Avatar
Re: Z1 crank
10 Aug 2006 00:45
#68446
Cam has to have EXACTLY twice the number of teeth as on the crank.
Seems strange Kawasaki would have cranks with different numbers of teeth. Unless they went to a different type of chain or were incompatible some other way.
  • Jeff.Saunders
  • Jeff.Saunders's Avatar
  • Vendor
  • Vendor
Re: Z1 crank
10 Aug 2006 05:46
#68466
In 79 & 80, Kawasaki sold the Mk II's - these engines were an evolution of the Z1 engine - they beefed up the center section of the crank and switched to 16 teeth - changed the cam sprockets to 32 teeth and went with a 124 link chain. Other than that, the components will pretty much interchange.
The Mk II engines were in the 79 & 80 A models, the 80 B model, the 80 & 81 C models, the 80 D model, the 79 & 80 E models and the 80 G model.
  • wireman
  • wireman's Avatar
Re: Z1 crank
10 Aug 2006 09:23
#68500
so 79 ltd could still use older crank as long as nothing else is updated.;)
  • RomSpaceKnight
Re: Z1 crank
10 Aug 2006 16:35
#68600
Ahhh, that is why it is a non-issue for me. All the parts I use to make my dragbike are 77 or older. I wish I had some MKII parts.
