79kz1000st----with a bit of a knock?
08 Aug 2006 00:03 #67948 by dropkik77
79kz1000st----with a bit of a knock? was created by dropkik77
i was riding it home from work and stopped at a light, in neutral. i dropped it into gear and hear a loud metallic noise... from then on it was a slight knock. i limped home about 200yrds. and let it sit. later, i took off the valve cover and didnt see anything that looked out of place...(although i guess im not so qualified to say). i took an extension magnet and stuck in where the oil goes to see if there were any metal fillings or pieces..and there wasnt. i took a wrench and tapped all over the outside just to see if there might be something on the outside thats making noise...there wasnt....any ideas?? i dont want to start it again as to not casue anymore damage...all help is appreciated!
thanks,
dropkik77
marc
08 Aug 2006 05:32 #67964 by wiredgeorge
Replied by wiredgeorge on topic 79kz1000st----with a bit of a knock?
The knock is something bumping as the engine turns. The only way to locate this knock is to start the engine and listed; perhaps with a stethescope. You can pick one up at Harbor Freight. The alternative is to squat next to the engine and listen. If you don't feel comfortable doing this and diagnosing the location of the knock, take it to a mechanic.
  • Duck
  • e vica na i sau na ga
08 Aug 2006 10:30 #68028 by Duck
Replied by Duck on topic 79kz1000st----with a bit of a knock?
You can use a long screwdriver or a piece of metal rod or pipe and listen around the engine to find the knock. Might not be in the engine. Tuch one end to engine and the other to your ear.
-Duck
