Question about oil cooler fittings for a 650
- OKC_Kent
07 Aug 2006 07:53
Does anyone have metric fittings similiar to the brass NPT?
I will be installing an oil cooler on my 650 soon, and Klasmo has some pricey metric fittings and banjo bolts that use a hose clamp to hold on the hose. Oldkawman has a few pages about using NPT fittings, and then you can have a threaded hose fitting which I like better than a hose clamp, but that means re-threading holes.
I want to avoid re-threading anything, and just screw on a fitting using Metric fittings, but I can't seem to find any on the net, any suggestions?
Cashion, OK
78 KZ650 B2 85,000+ miles
- Sandy
- Fly High,Tony
Re: Question about oil cooler fittings for a 650
07 Aug 2006 09:37
Kent...don't forget about the archives,Bud.
I just did a search,and there is a lot on info stored there...check it out.
I entered,"650 oil cooler" and came up with a lot of hits and info...do some reading,Bud,and I'm sure You'll get some good info.
1977 KZ1000 A-1
