Oil Leak at Clutch Pushrod
31 Jul 2006 17:27 #66179 by Mandrake
Oil Leak at Clutch Pushrod was created by Mandrake
I went through the process of changing my chain and sprockets. Once everything was back together I discovered a heavy oil leak at the seal where the clutch pushrod slides in. I've ordered a new seal but it seems strange that I should have such a heavy leak when there was no leaking prior. Any thoughts??
  • wireman
  • Visitor
31 Jul 2006 19:30 #66208 by wireman
Replied by wireman on topic Oil Leak at Clutch Pushrod
ya probably cleaned off the old layer of goo that was sealing it!:P
31 Jul 2006 19:54 #66221 by arobsum
Replied by arobsum on topic Oil Leak at Clutch Pushrod
or you pushed in some debris that you loosened up, the pushrod drug it into the seal. pull the rod out and clean it. then clean out the hole and try again.
  • RetroRiceRocketRider
  • ...bring in the machine that goes PING!
31 Jul 2006 21:11 #66244 by RetroRiceRocketRider
Replied by RetroRiceRocketRider on topic Oil Leak at Clutch Pushrod
Those clutch push rods are notorious for building up a layer of grime/dried oil/chain lube/etc on them and eventually causing the seal to leak.
When you go to replace the seal remove the push rod, clean the grime/etc off of it, then flip it 180* and reinstall it. That way the area that once had the grime/etc on it is now inside the engine and won't damage the seal again.
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
89 GSX1100F Katana = SLEEPING :-/
