Oil Pan Gasket
- Shoey949
Oil Pan Gasket
29 Jul 2006 12:47
I need to rethread the oil drain on my bike b/c somehow the PO screwed it up, so I need to take the oil pan off, and I was wondering if there was any way to get just the gasket for the oil pan without spending $100 for a full gasket set. I checked Bike Bandit and that don't have it.
Thanks,
Nate
Thanks,
Nate
'83 GPz550H2 w/'81 GPz 550D1 engine
Dynojet Stage 3 kit, MAC 4-1, UNI Pods, DYNA coils and plug wires, WG ignition mod
Grand Rapids, MI
Grand Rapids, MI
- wireman
- trippivot
Re: Oil Pan Gasket
30 Jul 2006 06:45
get a kawasaki one 5-7 bucks
if you cant find one let one of us know
are you going to have the hole welded and tapped?
- ronjones
Re: Oil Pan Gasket
30 Jul 2006 08:11
I spent a month trying to find one from all the normal sources. I ended up making one. Most car stores have gasket material. I used the thickest of 3 thiknesses. Used the old gasket as a template by laying the pieces on the material and spray paint over. Gets you in the ballpark for size and shape and you can trim the way you need to.
- Shoey949
Re: Oil Pan Gasket
31 Jul 2006 11:53
Neither bikebandit or kawasaki parts even shows a gasket in the schematic I was just going to have it drilled and tapped to a larger size.
Grand Rapids, MI
Grand Rapids, MI
