Piston / Cylinder measure
- texdan
27 Jul 2006 17:41 #65284
by texdan
Piston / Cylinder measure was created by texdan
Cylinder ID = 72.59mm
Piston OD = 72.32mm
1983 KZ1100 LTD L1
Sufficient?
Thanks.
Piston OD = 72.32mm
1983 KZ1100 LTD L1
Sufficient?
Thanks.
- steell
27 Jul 2006 18:35 #65306
by steell
Replied by steell on topic Piston / Cylinder measure
That's .27mm difference, over .010", sounds a little loose to me, but I don't know what the 1100's run for piston to cylinder clearance.
- hwms
- Thank you received: 1
27 Jul 2006 19:26 #65326
by hwms
Replied by hwms on topic Piston / Cylinder measure
- APE Jay
- Visitor
27 Jul 2006 22:43 #65381
by APE Jay
Replied by APE Jay on topic Piston / Cylinder measure
Are you measuring the piston at the bottom of the skirt and 90° from the pin hole?
Jay
Jay
- texdan
28 Jul 2006 06:28 #65406
by texdan
Replied by texdan on topic Piston / Cylinder measure
Good catch! No I did not measure the piston correctly. I measured from the very top edge of the piston. I'll have to try again this evening.
