Gas Mileage
- Chris1112
Gas Mileage
26 Jul 2006 16:57
I have a 79-kz 750 twin, and i am only getting 31 miles to the gallon is this normal? If this is not normal does anybody have some suggestions on what to start looking? The bike runs good I ride it to work almost every day, 25 mile round trip.
Thanks Chris
Post edited by: Chris1112, at: 2006/07/26 21:04
Thanks Chris
- kzmarvo
Re: Gas Mileage
26 Jul 2006 22:43
Sounds about right, how fast do you ride?
Watch it folks,i have sticky fingers when it comes to a nice looking set of handle bars:)
- steell
Re: Gas Mileage
26 Jul 2006 22:57
Sheesh, I hammer on them and waste a lot of gas and the worst I get is 45 mpg, with 55 mpg being normal
Sounds like it's time for a complete tune up, including adjusting the valve clearances.
- Chris1112
Re: Gas Mileage
27 Jul 2006 10:05
I pretty much ride at a normal pace 65 to70 on the highway. I have been thinking of doing a complete tune up for awhile now. Is there anything that you all would recommend that I don’t have listed?
Spark plugs
Change Oil
Change Oil Filter
Replace Points
Adjust valves
Clean Carburetors
Dial in the timing
Spark plugs
Change Oil
Change Oil Filter
Replace Points
Adjust valves
Clean Carburetors
Dial in the timing
- steell
Re: Gas Mileage
27 Jul 2006 10:34
Check the resistance of the coils and spark plug caps, and scour eBay for KZ440 timing advancer/pick up/ignitor to convert your bike to electronic ignition (but I bid on every one listed for a decent price)
Post edited by: steell, at: 2006/07/27 13:35
- Chris1112
Re: Gas Mileage
27 Jul 2006 11:03
steell wrote:
Thanks for the advice. I got a question or two.
What’s the benefit of changing the ignition. In addition, are there any good websites that show how to do this? About how much does it cost to do something like this?
- steell
Re: Gas Mileage
27 Jul 2006 18:43
It's only about a half hour job to install it, just use the KZ440 wiring diagram on
www.kz400.com
to see how to wire the ignitor.
I'm working on my third conversion
If you can't find an ignitor, loudhvx has a page on building your own using an HEI module from a GM car and three other componets. Costs less than $20 to build it.
- Biquetoast
- King Jeremy The Wicked
Re: Gas Mileage
27 Jul 2006 18:50
steell wrote:
This sounds just like that other dude a few days ago. He ended up having a bad plug wire or cap or something, right? Pretty much running on one cyl?
Just for the sake of corroboration, the worst I get is 44, and my average is around 48mpg. My entire commute is city and urban though, no highway.Sheesh, I hammer on them and waste a lot of gas and the worst I get is 45 mpg, with 55 mpg being normal
(1.) '75/'76 KZ400D - Sold
(4.) '75 KZ400D - Sold
kz750twins.com
kz750twins.com
- agawam
Re: Gas Mileage
27 Jul 2006 21:24
my twin is a shop project so far but I didn't estimate my milage before, just put in gas when it needed it, I have a 74 H1500 that gets about 22mpg but thats a "crank me up" bike
Post edited by: agawam, at: 2006/07/28 00:33
- BARNEYHYPHEN
Re: Gas Mileage
28 Jul 2006 08:13
1976 Kz900 bored out to 1024cc, 26's with 135 needle jets, Dyna and WG coil relay rewire. Ride fairly hard. 39.6 mpg.
- 79KZ
Re: Gas Mileage
29 Jul 2006 10:51
I must have some problems . I will give the bike a good tune up next weekend. Hopefully that will improve my gas mileage.
- arobsum
Re: Gas Mileage
29 Jul 2006 20:16
my 1977 kz1000 with vm28's and dyna ignition gets 35-38 mpg. usually around 35.
