clutch slipping - should I go with regular or race replacement?
- Trav
I searched for "slipping clutch" and saw a thread where a guy was reccomended to get a stock replacement vs the "street racer" setup EBC has. I guess maybe that still applies here?
The bike isn't a race bike, but it isn't exactly stock either, and I feel tempted to put in the 'best' stuff because it really isn't much of a price difference. However, I don't want it unstreetable or more annoying than it is beneficial. I am the type of person who would try a burnout and picking the front wheel up here and there, though..
Here is what denniskirk has to offer:
clutch plate selection at Dennis Kirk
Post edited by: steell, at: 2006/07/26 19:48
- 77KZ650
- Thank you received: 7
that is if they make them, im not sure now that i think about it, i think just the middle weights and big bikes, if they dont make em, and your friction plates are ok, see if the aftermarket springs will swap in
Post edited by: 77KZ650, at: 2006/07/26 18:55
07 MDP Rookie of the Year
- wireman
- Visitor
- KZDon
- Thank you received: 2
Midland, Ontario, Great White North
2004 650 V-Strom
farewell to 81 KZ550A2 - 82 GS750T - 83 GPz750 - R-Reg GT380 - 76 DT175 - 84 GPz550
- loudhvx
- Thank you received: 1616
use the aftermarket plates with stock style springs,your left arm will thank you!:whistle:
Done that. Yeah, it was easier on the left arm, but it slipped like crazy at highway speeds. I put in brand new stock springs too. It would only grab fully with the recommended aftermarket springs, and they were a BITCH on the left arm!
I called three different speed shops, and they confirmed the same thing. They each said almost the exact same thing "get the stock clutch, everything else is a waste of money". So I sprung for a stock set of disks and even used my old stock springs. The bike shifted so nicely with no slippage that all the money and time I wasted on the "performance" clutch didn't even bother me.
I have yet to feel a nicer, smoother, lighter clutch among all of my friends' bikes (although my buddy's KZ400 comes very close!).
This was on a 1981 gpz550.
Now if the bike is putting out more torque than stock, I can't say what will happen.
Post edited by: loudhvx, at: 2006/07/27 02:01
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- trippivot
- Thank you received: 3
less than 5 dollars for EBC brand-maybe a gasket and oil change also at the time you take the clutch cover off
- Trav
Lou, when you say "stock" clutch disks, do you mean stock spec (or someone who markets them as OEM spec) or literally "genuine kawasaki" clutch disks?
It's not an adjument thing, the cable was new put on by me when I got the bike, and I can loosen it up till it has all the play it needs and then some, but as soon as the clutch cable pulls taunt, the clutch slips. It would say to me that it is in the clutch itself, with disengagment happening so quickly. When I start out, I can let the lever out literally almost all the way before it even grabs at all.
- hydrolazer
\'79 kaw 1000 ltd
- Lorcan
- Speed Loony
- Thank you received: 59
760cc - 8.69@162mph
810cc, 211mph www.750turbo.com
www.stormdragbike.com
- RollingStock
73 z1900 street nitrous drag bike(powered but honda)
83 kz750 turbo street fighter project
- loudhvx
I mean from the dealer,genuine Kawasaki, oem disks. I tried to use brand new stock springs with aftermarket disks and it slipped a lot! The aftermarket disks only grabbed with aftermarket springs which were way too heavy for rush hour traffic.
My motor is stock 550 with a jet kit and Kerker.
1981 KZ550 D1 gpz.
Other links.
- guitargeek
- Thank you received: 50
I would agree with Trippivot and the tuning shops you have spoken to, use genuine Kawasaki plates only and some aftermarket springs. The EBC springs are about 10% heavier than stock. If you don't mind a really heavy lever action (I don't) then Kibblewhite do some "red" racing springs (they aren't actually red) that are about 30% heavier and will cope with about 150hp.
Just curious, what do you use for a clutch, Lorcan? What handles 230+hp?
After the clutch in my Seca Turbo exploded, I went with a Barnett clutch & springs (it was $20 cheaper than the Yammy parts!) It held really well for a long time, but eventually started to slip right before I got rid of the bike.
Trav, if you're going to pull your clutch plates and inspect them, you might consider hitting the steels with some sandpaper if they're glazed.
1987 KZ1000-P6 "Ponch"
1979 GS1000 "Dadzuki"
