Finally, after two months of wrenching, the bike has once again seen the glory that is sustained internal combustion. (Two months ago I bought the bike and it was in bad shape, started it, fried the wiring, been working on it all ever since).
Well I dragged it out into the street to give it a shot at actually taking me for a ride, but found out that the clutch is stuck (It's always something, isn't it). With the clutch lever pulled in I tried to put it in first, which jumped the bike forward and killed the engine. The cable seemed pretty tight, but I just couldn't get it to disengage the clutch. The bike has been sitting for a while (two months plus God only knows how long it sat outside in the yard of the guy I bought it from) so I'm going to try the rocking in gear trick I've read about in the forums.
Also, I did put drag bars on it, and I think I might need a shorter clutch cable anyways, but I can't tell if that's the clutch problem as I never had the bike running when I had the stock bars on.
Well here's a pic of my beauty nearing completion (need a seat and to fix that stinkin clutch)
Post edited by: 77Davo650, at: 2006/07/26 10:06
