Oil filter/change complication, Part II
- psychbiker
25 Jul 2006 15:46
[1981 KZ750 LTD]
NOW I AM READY TO GIVE UP!
I drained, uninstalled, and reinstalled everything.
> The main gasket was already properly seated on the filter plate
> No gouges/scoring seen anywhere on the filter plate
> Replaced the small gasket on the filter post (though the original seemed fine
> Thoroughly cleaned the filter housing on the motor, especially the rim that mates with the filter plate
> Checked for anything that looked liked it might be obstructed
> Only put in two quarts of oil
> CAREFULLY tightened the filter plate and oil drain bolts (finger tight and then until socket tight).
Within 10 seconds of the engine being on, oil just comes oozing from all over the filter plate.
What the hell could be going on?
There were no leaks before and I was able to unbolt everything by hand.
- wireman
Re: Oil filter/change complication, Part II
25 Jul 2006 16:01
laythe filter plate on something flat by itself to see if its warped from overtightening,or maybe it has a crack in it.
- Sandy
- Fly High,Tony
25 Jul 2006 17:00
Just a shot in the dark here(don't know the 750's too well) but are You sure that You haven't accidently doubled up on the gaskets,or seals?:huh: ...if that's even possible...not sure...
1977 KZ1000 A-1
- BSKZ650
25 Jul 2006 19:30
are you sure yo got the right filter?
77 ltd1000, current rider
76 kz900, just waiting
- psychbiker
29 Jul 2006 17:16
This has been suggested ...
I have done a web search and the Fram CH6012 is supposed to be the right one.
Am I mistaken?
Am I mistaken?
- psychbiker
29 Jul 2006 17:17
Thanks for the suggestion, but both gaskets (the plate and the post) are round and lay in a groove.
No way to double them.
- bemoore
29 Jul 2006 17:39
psychbiker wrote:
Unless there's an old one stuck to the block. I would double check that.
77 KZ650C1 w/Kerker 4-1
- Biquetoast
- King Jeremy The Wicked
29 Jul 2006 19:00
psychbiker wrote:
My twin 750s take the 6014. My 400 takes a 6012.
If it's a twin did you replace the "figure 8" o-ring?
If it's not a twin, this all should be disregarded....
EDIT: Now that I think about, there wasn't a twin in '81... So nevermind...
Post edited by: Biquetoast, at: 2006/07/29 22:00
Is this a twin?This has been suggested ...
Am I mistaken?
(1.) '75/'76 KZ400D - Sold
(4.) '75 KZ400D - Sold
kz750twins.com
kz750twins.com
- JR
29 Jul 2006 19:08
psychbiker wrote:
Assuming you have the 4 cylinder then you got the right oil filter.
I scanned a schematic of the oil filter etc from my Haynes manual and intended to post it here but if I shrink it down to fit the page it loses definition. If you want it then send me a PM or email at jroe@execulink.com and I'll email you it to you. Might help
Am I mistaken?
- mahoneyms
29 Jul 2006 20:44
"H"~
No new info to offer other than what others have suggested (and that you may have gotten a bad filter -- it's happened). Any pix of where the leak is? If you don't have a digi camera let me know & I can take some pix for you.
"M"
"M"
- fixer5000
30 Jul 2006 12:42
ive gotten oil filters that come with the o rings in the past and the larger one was too big in diameter for my bike. is it possible thats your problem here?? leaked like a sieve too....steve
1978 kz650b pretty much stock
massachusetts
massachusetts
- psychbiker
31 Jul 2006 15:30
Aw man ... it looked a bit too big (bulged as I attempted laying it in the track). But it seemed to fit in after tightening.
I can't believe I'm going to fish out the OLD o-ring from the pile of oil rags and try this ... AGAIN!
