Header collars
- pgrojean
- Pete
23 Jul 2006 13:23 #64065
by pgrojean
KZ1100 LTD - 83
R1200 C - 98
RD 250/350 73
KLR 650 - 06
XS 650 - 79
Header collars was created by pgrojean
I'm replacing my headers (83 - KZ11000 LTD). Got fairly good set of headers with mufflers on ebay. I have new copper washers but several of my collars are not "flat" and I'm thinking that they may not seal well when I put the new pipes on. Any comments/suggestions. Should I get new collars (Are they available?)
thanks for your help!
KZ1100 LTD - 83
R1200 C - 98
RD 250/350 73
KLR 650 - 06
XS 650 - 79
- wiredgeorge
24 Jul 2006 06:55 #64188
by wiredgeorge
Replied by wiredgeorge on topic Header collars
Not sure I can answer your question as I don't understand it. Good to see a local fella. Let me know if you ever need a hand with the bike. I live out towards Medina Lake off 1283.
- IowaKZ
- '80 G1 Classic
- Thank you received: 5
24 Jul 2006 07:13 #64194
by IowaKZ
1980 G1 Classic
Bettendorf, Iowa
Replied by IowaKZ on topic Header collars
I am not sure I understand your question either. However, I can tell you my experience: I did some work (painted header, etc) and I had to drop the header. When I put it back on, I saw that the flanges on my 'keepers' were not flat. By that I mean that they did not make a good 90 degee angle with the body, rather they were bent past 90 degrees in some places.
I attribute this to someone (maybe me) intalling these incorrectly so that they dont line up correctly with the collars.
Because of this, I can not get a good seat all the way around the collar and if I am not careful, the flange actually gets pinched between the collar and the engine fins in some spots.
To get around this problem, I actually installed 2 sets of copper gaskets. This adds a little distance and clearance for the collars.
I think part of the issue is that I have an after market header that doesn't quite line up length wise. I tried to take it apart to extend it, but the headers were rusted into the exhaust.
1980 G1 Classic
Bettendorf, Iowa
- pgrojean
- Pete
24 Jul 2006 08:42 #64211
by pgrojean
KZ1100 LTD - 83
R1200 C - 98
RD 250/350 73
KLR 650 - 06
XS 650 - 79
Replied by pgrojean on topic Header collars
Thanks for comments. The collars are warpped(sp?)- like they were over tightened once. So they may not apply even pressure to the 2 sleeves which in turn apply pressure to the flange on the header to make a good seal against the gasket/head. I may be overly concerned here, just don't want to get it all back together then have a leak. I guess it really depends on how warpped the collars are. I'm thinkin I will take them to a machine shop to be re-surfaced. I was wondering if this was a common condition and a problem that others have encountered before.
thanks much!!
thanks much!!
KZ1100 LTD - 83
R1200 C - 98
RD 250/350 73
KLR 650 - 06
XS 650 - 79
- ltdrider
- Thank you received: 17
24 Jul 2006 08:57 #64213
by ltdrider
'76 KZ900 LTD (Blaze)
'96 Voyager XII (Dark Star)
Greensboro, NC
Replied by ltdrider on topic Header collars
You must have bigger studs coming from the engine block than I do.
My collars go onto studs that fit a 10mm nut, and I'm sure I'd bust/strip a stud (a constant fear when I tighten them) before I ever warped the collar.
Greensboro, NC
- pgrojean
- Pete
24 Jul 2006 09:03 #64217
by pgrojean
KZ1100 LTD - 83
R1200 C - 98
RD 250/350 73
KLR 650 - 06
XS 650 - 79
I think I have the same size studs as you. Maybe the heat warped the collars, because you're right, it would have taken a lot of torque to bend a 3/4" collar.
thanks
thanks
KZ1100 LTD - 83
R1200 C - 98
RD 250/350 73
KLR 650 - 06
XS 650 - 79
- lifeliberty
24 Jul 2006 10:44 #64255
by lifeliberty
Replied by lifeliberty on topic Header collars
the collars on my aftermarket pipes are also warped (both sides are bent toward the head), I think MAC exhaust. I have heard that was common. I can't get the collars off to replace them anyways.
Post edited by: lifeliberty, at: 2006/07/24 13:45
- cary
24 Jul 2006 11:50 #64273
by cary
Replied by cary on topic Header collars
I have the same bike as you, and had a hell of a time getting the pipes to seal, I got a set of reusable gaskets from redlinecycle.com and it sealed up great the first time. BTW - you don't have any parts from the ltd you'd want to sell?
- pgrojean
- Pete
24 Jul 2006 12:10 #64276
by pgrojean
KZ1100 LTD - 83
R1200 C - 98
RD 250/350 73
KLR 650 - 06
XS 650 - 79
Cary - I've got a set of old and somewhat rusted headers that are original. Shipping cost plus $20. Also, instrument cover.
I'm going to try to have my collars machined/resurfaced. I'll let you all know how it goes.
thanks
peter
thanks
peter
KZ1100 LTD - 83
R1200 C - 98
RD 250/350 73
KLR 650 - 06
XS 650 - 79
- pgrojean
- Pete
31 Jul 2006 20:05 #66226
by pgrojean
KZ1100 LTD - 83
R1200 C - 98
RD 250/350 73
KLR 650 - 06
XS 650 - 79
Just to close the loop on my oringinal question. I took the collars to the shop and had them machined. Top, bottom and insides resurfaced. Cost $20 - probably should have cost more but the guy took pity on someone who obviosly was on a learning curve and enjoying working on his bike. Used new copper washers that I got from ebay. Steel wooled the whole lot. Put everything on the bike and thank God everything lined up. No leaks and my old bike - with almost new headers - looks great!! Glad I didn't have to pay me by the hour
KZ1100 LTD - 83
R1200 C - 98
RD 250/350 73
KLR 650 - 06
XS 650 - 79
