rubbxr cam rollxr
  • bangshift440rt
  • bangshift440rt's Avatar Topic Author
rubbxr cam rollxr
21 Jul 2006 19:21
#63780
i havx xrxry rollxr in thx cam chain systxm xcxxpt thx bottom onx right abovx thx crank. it sxxms likx maybx its just for noisx control and i think if i kxxp thx chain tight it will bx finx anyways, has anyonx xvxr donx this? any hxlp is much much apprxciatxd.
  • Nevco48
  • Nevco48's Avatar
Re: rubbxr cam rollxr
21 Jul 2006 19:35
#63786
I think you had bxttxr fix your kxyboard bxforx you worry about your bikx!!:laugh: :laugh:
  • steell
  • steell's Avatar
21 Jul 2006 23:00
#63825
Looks like the "e" key is broke :D
I don't think any of the rollers are there for noise control, but then I don't know what model you are talking about.
  • Lorcan
  • Lorcan's Avatar
  • Speed Loony
22 Jul 2006 12:02
#63886
:laugh: :side: :silly: :whistle:
760cc - 8.69@162mph
810cc, 211mph www.750turbo.com
www.stormdragbike.com
  • Nevco48
  • Nevco48's Avatar
22 Jul 2006 15:36
#63906
Bangshift, come back, were just messin' with ya. Try typing a word with the letter "x". Maybe you get an "e" ?
  • bangshift440rt
24 Jul 2006 09:32
#64222
i got a new keyboard. i figured the x's would be the easiest to interpret as the missing e. anyways, i am going to run the engine without this roller i believe because i was lost when i put the engine together with no manual. (i know i know it was dumb) and now i cant get the cylinder back off to put it in. so i will let you know what happens :S :dry: PS kz900 roller betwen the crankcase and the cylinder.
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
24 Jul 2006 09:49
#64228
I strongly recommend you try and pull your cylinder again. Those rollers are important to keep (as even as possible) tension on the cam chain. If the chain hops a tooth, you'll be replacing more than a roller:ohmy:
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • Sandy
  • Sandy's Avatar
  • Fly High,Tony
24 Jul 2006 09:52
#64230
DON'T DO IT!!!
Without that roller,You won't have proper tension on Your cam chain,and You will more than likely get chain slop(lots of noise) and You also run the risk of the chain jumping,and You'll introduce valves to pistons!!
That roller is a vital part!
You'd be better off riding the bike with the rear tire off the rim.:whistle:
1977 KZ1000 A-1
  • bangshift440rt
25 Jul 2006 09:03
#64550
ok then my next question is, i used copper/silicon sealant on the base, how do i get the cylinder back off? i tried and tried and am betting i would crack the block before the cylinders came off.
  • trippivot
  • trippivot's Avatar
25 Jul 2006 13:14
#64616
never use sealant on the base gasket!
pry with a shim made of wood
tap and pry until it does budge
"GENTLY"
