Clutch problems HELP
- odl666
18 Jul 2006 22:41 #63073
by odl666
1978 kz 650b with gpz faq mods cams carbs polished and ported
1979 gs750e
1972 bsa lightning under construction
Clutch problems HELP was created by odl666
I took off my cover for my clutch to take mychain off. Well when i wne tot put everything back togeather my clutch would no longer engage? any sugestions could i of maybe put it back togeatyher wrong, also it is now leaking oil out of that area. Didnt before. Thanks
1979 gs750e
- wireman
- Visitor
18 Jul 2006 22:44 #63075
by wireman
Replied by wireman on topic Clutch problems HELP
did you remove the cable or anything inside?:whistle:
- Sandy
- Fly High,Tony
- Thank you received: 13
19 Jul 2006 08:38 #63142
by Sandy
1977 KZ1000 A-1
Replied by Sandy on topic Clutch problems HELP
oddl666...please put Your bike model and year,in Your signature ok,so We all know what bike You're referring to.
More details would be good also,Bud.
It probably has something to do with the cable gear/carrier...the nylon worm-gear on the inside of the cover...or where the cable comes into that cover.
1977 KZ1000 A-1
- RomSpaceKnight
- Thank you received: 2
19 Jul 2006 10:39 #63163
by RomSpaceKnight
Replied by RomSpaceKnight on topic Clutch problems HELP
I am assuming you mean the left side cover, that covers the counter sprocket and clutch actuator worm gear. I would think you have reassembled incorrectly. Be careful with how that worm gear goes back together. I managed to friction weld my pushrod at both ends.
- odl666
19 Jul 2006 17:55 #63233
by odl666
1979 gs750e
Replied by odl666 on topic Clutch problems HELP
1978 kz 650b i may of reassembled wrong so i will check. thanks
1979 gs750e
