Valve lapping compound question
  • inline4
  • inline4's Avatar Topic Author
18 Jul 2006 10:02
#62899
Once again, here is this one-horse-town called Memphis, I can't find valve lapping compound ANYWHERE!:angry:
I've only found valve "grinding" compound in one place. I've even called several shops, even small engine repair shops and no one knows where to find the stuff other than the internet.
On ebay I've seen a brand called Clover which comes in different courses. Is there anything else out there that you folks suggest?
Thanks,
Jim
  • steell
  • steell's Avatar
Re: Valve lapping compound question
18 Jul 2006 10:11
#62902
AutoZone carries Permatex brand in a tube. and Napa carries it also. Best selection I have found is on the net though.
  • inline4
18 Jul 2006 10:28
#62907
In either place I've only been able to find grinding compound. Permatex in a tube at AutoZone; Permatex/Napa brand in a jar (water & oil-based) at Napa.
All I can say is DON'T MOVE TO MEMPHIS!
This place sucks and for many reasons.:blink:
  • CTSZ1
  • CTSZ1's Avatar
18 Jul 2006 10:40
#62908
I would have thought with Lunati in town they'd have lapping compound somewhere. But I guess they don't actually use it. Might give them a call and see if they know a source.
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
18 Jul 2006 10:41
#62910
I found it at O'reillys.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • trippivot
  • trippivot's Avatar
18 Jul 2006 10:45
#62912
Walmart has it here in IA
  • steell
  • steell's Avatar
18 Jul 2006 10:59
#62913
Grinding compound is just another name for it, same stuff, just an abrasive paste.
It is available in several different grades, from very fine (as in 600/800 grit) to really course (as in 40 grit).
  • inline4
18 Jul 2006 11:04
#62917
He steel, only one grade of it here. It's called "F".:woohoo:
  • EddieBoy
  • EddieBoy's Avatar
18 Jul 2006 11:29
#62922
im here in memphis as well... i use clover brand in the green two sided can. coarse on one side fine on the other. i havent used it in a bit but i can go out to the garage and look for it if you want to use it. it lasts a long time. i use the course to start then the fine to finish....btw it works good for rounded off nut heads to!!! put some course inside your boxed end wrench then a lil on the rounded nut. works almost everytime:) Ed
