Any ideas, wierd problem.
  • 77_650B1
  • 77_650B1's Avatar Topic Author
17 Jul 2006 08:46
#62595
So I'm riding around on my bike, noticing that she doesn't have enough power down low in the revs to start off in first gear. She bucks, I up the revs a bit, and off she goes. So i put my hand behind the exhaust pipes(no crossover on mine) and the one coming from 3,4 is more forceful than the one coming from 1,2. Now I know that the engine is firing on all fours, cuz every pipe is hot.
So my question is, is it rings, carb related, or valve clearance? Just lookin for all culprits so I can track this down.
1977 KZ650-B1
-Dual Discs
-Dyna-S
-WG Coil Mod
-Alloy Wheels
  • OKC_Kent
  • OKC_Kent's Avatar
Re: Any ideas, wierd problem.
17 Jul 2006 12:24
#62671
What do your plugs look like? How's the point gap and timing? How about the valve clearance?
Post edited by: OKC_Kent, at: 2006/07/17 15:37
Cashion, OK
78 KZ650 B2 85,000+ miles
  • JR
  • JR's Avatar
17 Jul 2006 17:47
#62746
Hmmm.........might be worth investing in a compression tester and checking compression on each cylinder.
