Tip for removing long standing fasteners...
- hardr0ck68
- Who put the what in the where?
Re: Tip for removing long standing fasteners...
07 Nov 2005 22:58
well i guess im the odd man out here. I always learned "buy tools if you NEED to; take tools from work whenever you can, and if you dont have the right tool the vice grips are over there"
I buy the el cheapo tools whenever i get a chance to, why? because i would rather have toys to work on, than tools to look at. Just my .02
1977 kz650 c1
bought it because I was told it would never run again...I like to prove people wrong.
- Garn
08 Nov 2005 02:26
I use a "VESSELs" impact wrench, with a philips head blade. I think they are a Japanese company. I'm looking to buy another they are good quality and compact. I use them to give the final tighten on clutch, alt and other covers.
I never use a torque wrench on the 6 mm bolts for the cam retaining cups... Too easy to strip!
Regardz.
Regardz.
1 x 73 Z1 (Jaffa), 74 Z1A, 76 Z900-A4
1 x 73 Yamaha TX500 & 98 fzx250 Zeal
Sydney Australia
Sydney Australia
- Duck
- e vica na i sau na ga
08 Nov 2005 05:22I never use a torque wrench on the 6 mm bolts for the cam retaining cups... Too easy to strip!
Right, a torque wrench is no substitute for common sense. It's more like a 'second opinion'. The value of the opinion depends on the tool and where one is in it's calibration range.
-Duck
- luvmykaw
09 Nov 2005 07:12
Another tip from the old KZR site (now archives), is the candle wax trick. Heat a screw/bolt whatever up, then touch some wax to it, parafin I think, can't remember. The wax wicks down the threads and acts as a lubricant.
- Duck
09 Nov 2005 09:08
Neat
I will give this a try next time.
-Duck
-Duck
- steell
09 Nov 2005 09:30
For the screwdriver trick, it's a lot better to use a screwdriver with a through shank, that's one where the metal shaft extends all the way through the handle and is exposed on the end.
- Biquetoast
- King Jeremy The Wicked
09 Nov 2005 11:10
luvmykaw wrote:
Yeah... I remember that...
Found it:
www.kzrider.com/forum/viewthread.php?tid=14897
Found it:
(1.) '75/'76 KZ400D - Commuter
(4.) '75 KZ400D - Sold
kz750twins.com
kz750twins.com
- dgfischer
09 Nov 2005 15:30
I've found that when you go to put the impact driver on the screws, it often helps if you take the screwdriver blade part of it and gently hit it with a hammer onto the screw. It usually straightens out the tip of the screw so when you put the impact driver together and whack it, it has a better grip on the screw.
Ive also found that a drill works great for getting those stubborn ones out. Use a drill bit bigger than the shank of the screw to keep from putting the threaded remains deeper in the block.
Daniel
Daniel
- savedrider
- 1975 Z1-B 900
09 Nov 2005 18:19
Sorta off topic, but has anyone had a Craftsman torque wrench calibrated? I'm sure mine is due. Wondering how long the turn around time is. I use mine often.
Get right or get left! <*{{{><
