Tear down
- lovethemkzs
Tear down
Yesterday 18:36
Okay I took all the covers off the side with my new cylinder head and valve cover and I plan on getting them well I am going getting them powder coated I know the powder coating ain't going to match the bottom half so I decided I'm going to take the bottom half off and have everything powder coated
My question what should I be on the lookout for and what should I do to make sure I don't screw nothing up for the most part I'm thinking about just taking the crank and pistons out in one shot after removing the top half and same thing with the transmission your turn lol.
- kzstreetfighter71
- Atlantic West Coast
Re: Tear down
Yesterday 04:34
What engine/year bike are you working on?
way way way too many bikes to list and the list still gets longer.
- lovethemkzs
Re: Tear down
Yesterday 05:30
I apologize for that 1982 KZ 1100 D1 Spectre
my thoughts since the bottom end doesn't split in the center vertically but horizontally I can basically get away just taking the top half off
then just left out the crank with the Pistons and do the same with the transmission after disconnecting the shaft bolts from the transmission at the side and put that on the side and just reassemble again later
I know I probably got a few little things like gear shifter maybe linkage an oil pump stuff like that.
Re: Tear down
Yesterday 07:05
Please carefully consult the factory service manual for both disassembly and re-assembly before proceeding.
The following user(s) said Thank You: StreetfighterKz, slmjim+Z1BEBE
- asphalt900
Re: Tear down
Yesterday 09:20
Crankshaft rods have to be disconnected from pistons or..Not possible to lift out as one assembly. Lower half of cases are easy, just lifts off. If you're considering powder coat for head/camcover and cylinder check with your vendor first before you assume they will even do it. A lot of companies won't! Especially the Head because of all recessed inner portions of all those fins, powder won't get in there. An elaborate masking job needs to preformed too!!
The following user(s) said Thank You: StreetfighterKz, Dragbike_Mike
Re: Tear down
Yesterday 11:12 - Yesterday 11:13
Also powder coat melts at 260 degree’s. Make sure you keep it off and gasket faces or bearing housings
Last edit: Yesterday 11:13 by Wookie58.
Re: Tear down
Yesterday 12:59
Yup. Ceramic coating would be a better choice.
