Cutting off kickstart shaft
  • Daveuk
  • Daveuk's Avatar Topic Author
19 Nov 2026 10:12
#929222
I am Fitting rearsets to my 1980 kz 1000.
 I intend to cut the end of the kickstart shaft and fit a cnc plate.
  Could the shaft engage by itself and trash
​​​​​​​   the gearbox.
  • kzstreetfighter71
  • kzstreetfighter71's Avatar
  • Atlantic West Coast
Re: Cutting off kickstart shaft
19 Nov 2026 10:19
#929224
Why do you need to do that? Im not sure you will ever get it tight enough to fit a cover plate or you are in danger of nicking the engine case and you wont get a tight seal. Normally we just leave the mechanism out when rebuilding the engine. a simple rubber cover like the Z1r will tidy it up nice.
way way way too many bikes to list and the list still gets longer.
The following user(s) said Thank You: Cra-z1
  • kzstreetfighter71
19 Nov 2026 10:22
#929225
The answer is no, the shaft would not do that but give a good think on what your planning to do for little or no gain.
  • kzstreetfighter71
19 Nov 2026 10:29
#929226
  • Daveuk
19 Nov 2026 10:50
#929227
Thanks for the replies, just looking to tidy
up that side of the motor.
 I am fitting a clear clutch cover and cnc points cover to go with the kickstart cover.
​​​​​​​ Would i need to refit the ratchet mechanism on the remains of the shaft.
  • zed1015
  • zed1015's Avatar
19 Nov 2026 10:51 - 19 Nov 2026 10:53
#929228
Never heard such a daft idea.
The exposed shaft would never interfere with rear sets or really be a visual distraction so just make a slip on cover for it as already recommended or make a cnc spacer to bring the original cover out far enough to fit an alloy blanking plug instead of the shaft seal.
Another alternative which is tricky but possible is to drop the sump and remove the circlip that retains the kickstart ratchet.
Once removed the kickstart shaft will slide out from the case and the ratchet gear etc will drop out of the sump and then you can fit a blanking plate which are already available to buy..
Last edit: 19 Nov 2026 10:53 by zed1015.
The following user(s) said Thank You: MFP-Joe, Dragbike_Mike
  • StreetfighterKz
  • StreetfighterKz's Avatar
  • Online
19 Nov 2026 11:33
#929230
This…
I turned up a quick cover for my Kz650 since I can’t use the kicker with my rearsets.   Took all of 15-20mins and is held on with a small set screw.
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
The following user(s) said Thank You: Injected, sf4t7, Dragbike_Mike, Daveuk
  • Daveuk
19 Nov 2026 11:54
#929232
Thanks again for all the replies
 I work in an engineering company and a standoff spacer would be hell of a Friday
afternoon job.
  Think I will will just get a cover turned for
​​​​​​​  the splines.
  • Injected
  • Injected's Avatar
19 Nov 2026 12:45
#929233
I had a spline cover on mine for a bit but decided to split the cases and remove the kicker assembly. I have a shallow cover pressed in from the inside... forgot to bring it to the welders when I had the ring for the lockup done!
1978 KZ650B2 modified project
  • zed1015
  • zed1015's Avatar
19 Nov 2026 12:47
#929234
I usually modify a kickstart lever ( see pic ) so that it swings out further to miss my rear sets but on my latest build i'm going to extend the actual shaft and bring the cover out with a spacer so that the stock kicker can be used.
It may get tied into a couple of bolts that hold the clutch cover if the assembly shows any flex from the added leverage.
  • Daveuk
20 Nov 2026 07:51
#929254
  • Daveuk
20 Nov 2026 07:54 - 20 Nov 2026 07:59
#929255
I did it anyway, points cover on its way from webike.
Last edit: 20 Nov 2026 07:59 by Daveuk. Reason: Mistake
