1979 KZ650 B3 valve clearances
- Vietvet
09 Nov 2026 19:38
I have just fitted the camshafts in and the timing looks OK. I am ready to do the valve clearances but I seem to remember reading on this forum some time ago about the measurements in the manual seem questionable. The book is saying 0.08-0.18 mm for both inlet and exhaust. Does this sound OK.
Tantanoola South Australia.
1979 KZ 650
1979 KZ 650
- Warren3200gt
The following user(s) said Thank You: Vietvet
- Injected
Re: 1979 KZ650 B3 valve clearances
11 Nov 2026 04:35
I don't adjust to less than .006" and if its .008" or above I try to get less.
1978 KZ650B2 modified project
- Warren3200gt
11 Nov 2026 04:58 - 11 Nov 2026 05:00its a 650. 0.08 -0.18 is the correct clearance.I don't adjust to less than .006" and if its .008" or above I try to get less.
Last edit: 11 Nov 2026 05:00 by Warren3200gt.
11 Nov 2026 05:37
Valve clearance always goes down, not up, so keep this in mind as you go along. I always target the high end of the range to extend the time, particularly on bikes like the 650 since the cams must be removed to change shims.
The following user(s) said Thank You: Injected, Vietvet
- Injected
11 Nov 2026 06:01Exactly, that's why .003" is too tight.Valve clearance always goes down, not up, so keep this in mind as you go along. I always target the high end of the range to extend the time, particularly on bikes like the 650 since the cams must be removed to change shims.
12 Nov 2026 11:01 - 13 Nov 2026 05:42
FYI
0.08mm = 0.00315"
0.18mm = 0.00708"
0.08mm = 0.00315"
0.18mm = 0.00708"
Last edit: 13 Nov 2026 05:42 by TexasKZ.
The following user(s) said Thank You: StreetfighterKz
- Vietvet
12 Nov 2026 15:05
The local Kawasaki Dealer didn't have any 13mm shims that I needed so I used a supplier who makes the shims they are called "Precision Shims" in Melbourne and they make the shims in increments of 0.02mm instead of the 0.05mm that the Kawasaki ones come in. The 13mm shims are $9.00 each and they will post them to you. I have used them before when I was adjusting the clearances on a KZ1000 I had.
1979 KZ 650
1979 KZ 650
