1982 KZ1000LTD
- rickysnicker
1982 KZ1000LTD
25 Oct 2026 07:32
There is one for sale locally. It supposedly has only 12,000. To be honest I'm only interested in it for the engine. I have researched and believe I know the correct answer. This engine can replace the engine in my 2000 KZP. I know the wiring is a bit different. I think I'd have to swap out the stator. Other than that, would this be a straight forward swap? I'd probably part out the rest of the other bike.
- bound
- If you ain't HURTIN' you ain't LEARNIN'!!
Re: 1982 KZ1000LTD
26 Oct 2026 08:13
As straight forward as straight forward can get. I cant seem to tell any difference at all between the ltd and police j engines. The stator should be the same across all models of the j engine. I actually have a kzp stator in my csr so don't worry about that.
1982 KZ1000M2 CSR
1983 KZ440D5 LTD
1985 GPz 550A2
Craig
1983 KZ440D5 LTD
1985 GPz 550A2
Craig
The following user(s) said Thank You: rickysnicker
