Multiple screws snapped inside the block
- 650fromHELL
26 Sep 2026 10:56
How cooked am I? For context I bought my kz650 from an idiot teenager that knew zero about bikes. It was also junkyard quality but I took on the challenge of bringing it back. It's almost done now, 2+ years later and after buying a replacement sprocket cover I now know why the original was lost to time. They snapped 4 of the 5 screws that holds the cover on into the crankcase. I've tried alot to remove them with no luck. What do I do? I'd ride with no cover but you need the cover to actuate the clutch plus safety or whatever but mainly the clutch. I'm attaching photos, if anyone has any suggestions or ideas I'm all ears. And no a new engine, crankcase, or anything in between is not on the table. I've spent well past what the bike is worth at this point.
- kimchella
Re: Multiple screws snapped inside the block
26 Sep 2026 13:23
Personally I would drill out and tap new threads,
Rich.
Rich.
KZ650B1 frame number 225
New Zealand
New Zealand
- 650fromHELL
26 Sep 2026 13:29
I've tried but all the snaps arent clean. They are at weird angles that make the drill bit wander. Also the original screws are hard alloy that apparently dulls 75% of drill bits.
26 Sep 2026 14:45
That's what they make cobalt drill bits for.
Use a center punch in the middle of the busted screw and make a dimple. Drill a small hole in the screw, and work the drill bit sideways as needed until the hole is dead center. Then move up to the next size drill. Using left hand drill bits works well. When the old screw is just a shell, it will likely spin out when drilling.
26 Sep 2026 17:55
I would probably pull the engine, dismantle it and use a drill press.
- bound
- If you ain't HURTIN' you ain't LEARNIN'!!
26 Sep 2026 18:24 - 26 Sep 2026 18:24I think based on what OP has said, he doesnt want to do this. I personally have gone through what OP has said before but for the injector bolts on my cars cylinder head. It was not a fun experience but for something like this there is generally a low risk. I would helicoil or tap threaded inserts into the holes. You probably aren't going to be able to get the drill straight, its just a part of the game. I dont think its even worth it to try to ez-out the screws, just drill through them. It's not pretty.I would probably pull the engine, dismantle it and use a drill press.
1982 KZ1000M2 CSR
1983 KZ440D5 LTD
1985 GPz 550A2
Craig
1983 KZ440D5 LTD
1985 GPz 550A2
Craig
Last edit: 26 Sep 2026 18:24 by bound. Reason: pictures aren't getting added
- Warren3200gt
26 Sep 2026 23:25 - 26 Sep 2026 23:27
Hold a nut over the end of the broken screw and weld fill the nut center to the snapped screw. The heat from the weld will break the galvanic corrosion and then simply use a spanner to unscrew it.
might take a couple of attempts but you wont be in danger of trashing the engine case.
Last edit: 26 Sep 2026 23:27 by Warren3200gt.
The following user(s) said Thank You: StreetfighterKz, Dragbike_Mike, Wookie58, bound, z250b1
- 650fromHELL
27 Sep 2026 10:01
This might have to be the move.
- StreetfighterKz
27 Sep 2026 13:17
youtube.com/shorts/iUkCrgZ94pY?is=DBBDwJCKAQn36qXu
Here’s what I did on my 650 when I snapped
bolts off in the trans door cover. The weld filler won’t stick to the aluminum, just the broken screw and nut.
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
The following user(s) said Thank You: bound
27 Sep 2026 15:28What I read was no to a new engine or crankcase. It takes some work to pull and dismantle the engine but it would preserve the existing holes. But if you can weld then I like Doug's solution best.I think based on what OP has said, he doesnt want to do this. I personally have gone through what OP has said before but for the injector bolts on my cars cylinder head. It was not a fun experience but for something like this there is generally a low risk. I would helicoil or tap threaded inserts into the holes. You probably aren't going to be able to get the drill straight, its just a part of the game. I dont think its even worth it to try to ez-out the screws, just drill through them. It's not pretty.I would probably pull the engine, dismantle it and use a drill press.
- bound
27 Sep 2026 17:15Yes i agree dougs solution is the best if there is access to a welder. The only thing that would suck about dismantling the engine is lots of time and money for gaskets. Broken bolts suck, no way around it.What I read was no to a new engine or crankcase. It takes some work to pull and dismantle the engine but it would preserve the existing holes. But if you can weld then I like Doug's solution best.I think based on what OP has said, he doesnt want to do this. I personally have gone through what OP has said before but for the injector bolts on my cars cylinder head. It was not a fun experience but for something like this there is generally a low risk. I would helicoil or tap threaded inserts into the holes. You probably aren't going to be able to get the drill straight, its just a part of the game. I dont think its even worth it to try to ez-out the screws, just drill through them. It's not pretty.I would probably pull the engine, dismantle it and use a drill press.
1982 KZ1000M2 CSR
1983 KZ440D5 LTD
1985 GPz 550A2
Craig
1983 KZ440D5 LTD
1985 GPz 550A2
Craig
- Cra-z1
29 Sep 2026 19:11
The worst thing is a broken tap in one of those cover holes.
