Starter - bang!!!
- bound
- If you ain't HURTIN' you ain't LEARNIN'!!
Starter - bang!!!
15 Sep 2026 20:08
My kz1000 csr will randomly make a frown-inducing noise when I turn over the engine with the starter SOMETIMES. It will randomly make a terrible metallic clank like a hammer hitting the engine and when this happens the engine will not start usually; either because i freaked out or there is some mechanical problem. Here is my best worded impression:drrr-duh-duh-duh-duh-CLANK! I do not like this noise and it sounds like its from the starter area but i cant be sure. When this happens I try to start the bike again and it usually does. Does anyone know what this could be? FYI this does not happen often.
1982 KZ1000M2 CSR
1983 KZ440D5 LTD
1985 GPz 550A2
Craig
1983 KZ440D5 LTD
1985 GPz 550A2
Craig
- asphalt900
Re: Starter - bang!!!
16 Sep 2026 04:08
If after the duh,duh,duh, Clank. Does starter continue to spin or just nothing? More pronounced when engine is cold or hot?
- bound
16 Sep 2026 09:07
It's hard to remember but I thought that I could hear the starter a bit after the clank. I only noticed this happen on a cold engine but I do not remove the possibility of it happening on a hot engine.
1982 KZ1000M2 CSR
1983 KZ440D5 LTD
1985 GPz 550A2
Craig
1983 KZ440D5 LTD
1985 GPz 550A2
Craig
- asphalt900
17 Sep 2026 03:33
Could a handful of things. These Mitsuba starters came in a couple versions, 2 or 4 brush. Yours i believe is the 4. So if starter isn't strong enough or supply of amperage lacking you can get that backlash clunk. Another issue could be the 3 Allen Sprague starter clutch bolts are working loose?
The following user(s) said Thank You: bound
